Carburator linkages repair
#1 Carburator linkages repair
Do you know a dealer for the small screw with a split head wich are at the top and bottom of some of the carburator linkages ?
There is some hammer dot on the head of the link ( where there is a spring and a "T" ) to securise the screw but you hurt them when you unscrew.
Purhaps have you an other solution ?
Michel
#2 Re: Carburator linkages repair
Perhaps if you look on the SNG Barratt website here:
https://www.sngbarratt.com/uk/#!/Englis ... ING%20RODS
you will find what you are looking for.
Jerome Lunt
2008 MX-5 NC PRHT - now gone
#3 Re: Carburator linkages repair
Thanks Jerry but I don't speak about that linkage, it's parts off the linkage before this one.
I have a LHD of course.
Michel
#4 Re: Carburator linkages repair
Hi Michel...not sure what screws you want..a photo of them on the linkage would be good...if its an SU part then try Burlan http://sucarb.co.uk/?SID=1k1qt4talm8jj5esbbe8bilp97 Steve
#5 Re: Carburator linkages repair
It was clear in my head, but visibly ONLY in my head.
https://www.sngbarratt.com/uk/#!/Englis ... ROLS%20LHD
It's the small screw on the heads of the parts 15 or 9
Hope everybody understand...
Michel
#6 Re: Carburator linkages repair
Hi...so its the screws that hold the balljoints on the linkage....have a look through the reproduction parts section and try Richard Smith..his details will he in there he makes lots of parts viewtopic.php?f=2&t=6798 Steve
#7 Re: Carburator linkages repair
Thanks a lot steve.
I'll try.
I'll try.
Michel
#8 Re: Carburator linkages repair
You might also try Joe Curto. http://joecurto.com/
He was very helpful over the phone when I was looking for some internals.
#9 Re: Carburator linkages repair
The linkage heads (9 & 15 as you describe them) are available on eBay, certainly eBay.com as they are commonly used to control popular US carburetors.
1969 Series 2 FHC
1969 Series 2 FHC
