In a Dither over Interior Trim Removal
64etype
#21 Re: In a Dither over Interior Trim Removal
Post by 64etype » Thu Mar 09, 2017 3:05 pm
I'm installing the interior on my car using Weldwood Landau Top high temp contact adhesive. The clean up instructions on the container say to use Toulene or Xylene. I use Xylene to soften and clean brushes that have cured adhesive on them for weeks. Not as nasty as MEK in terms of fumes. I've used it to clean off fresh adhesive from interior surfaces and it doesn't seem to damage the hardened clear coat paint. On the other hand, I haven't let it sit on the surface for an extended time. Anyway, it does softened old adhesive....
Eric
rfs1957
#22 Re: In a Dither over Interior Trim Removal
Post by rfs1957 » Thu Mar 09, 2017 7:41 pm
I tried everything known to mankind with no success, until a secret Forum poster whispered in my ear that I the Jag came with an in-built tank full of the necessary product.
The proper mask, decent ventilation, soaked into a rag left on top of the glue for 10 minutes, and - Bingo, the glue comes off totally in rubbery wisps and flakes, and leaves unmarked paint.
PS - no, it's not engine-coolant, and it's not windscreen-wiper wash.
Julian.P
#23 Re: In a Dither over Interior Trim Removal
Post by Julian.P » Thu Mar 09, 2017 10:48 pm
I use many Evo stik products including contact adhesive, Evo stik 191 adhesive cleaner is the best product for removing glue, ensure that it's used in a well ventilated area with correct PPE.
Julian.
rfs1957
#24 Re: In a Dither over Interior Trim Removal
Post by rfs1957 » Fri Mar 10, 2017 7:18 am
My understanding was that this Evostick 191 Remover product also damaged paint ?
If not then the whole debate was a waste of time and that is indeed what I should have been using.
Please advise.
#25 Re: In a Dither over Interior Trim Removal
Post by mgcjag » Fri Mar 10, 2017 9:15 am
Hi Rory....thats the info i got from a few adhesive manufacturers...evostick is not suitable for automotive.....having said that im sure its used quite a lot as is the common choice if you want a contact adhesive.....but having found out...i like you went for an automotive option
rfs1957
#26 Re: In a Dither over Interior Trim Removal
Post by rfs1957 » Fri Mar 10, 2017 12:15 pm
Not sure we aren't at cross-purposes ; as a glue I'm sure Evostick is great, wholly appropriate, like any other contact-adhesive, and I haven't used an alternative "automobile" product because I'm way off fitting anything back yet.
My quandry was just how to remove the old stuff ; either the 191 Remover doesn't affect paint, in which case it is THE answer, or the stuff in our big tanks remains the best solution I've found to date.
#27 Re: In a Dither over Interior Trim Removal
Post by mgcjag » Fri Mar 10, 2017 1:00 pm
Hi Rory...yes my mistake...you wer talking about removal.......but re useing evostik as a trim adhesive it is not recomended......some of the glue people i spoke to said that it can leach through the vinyl.....especially the high impact evostick....thats why all the trim shops use an automotive glue
64etype
#28 Re: In a Dither over Interior Trim Removal
Post by 64etype » Fri Mar 10, 2017 4:58 pm
I just finished removing all the wood tack strips from both seat to replace them with rubber/poly windshield tack strip prior to upholstering. I had used both upholstery glue and rivets to apply the wood a couple of years ago. I used Xylene on one seat and gasoline on the other for a comparative test. The Xylene dissolved the adhesive virtually immediately, but when I rubbed off the residue, some paint came off with it. The gasoline was slower to act and took a little more rubbing with a wetted hand towel to get the glue off. It also took a little paint with it, but not as much. This is rattle can paint over a primer on the seats. Didn't break through to the metal, but probably would have if I'd kept rubbing (for both solvents). I didn't care as I can easily repaint the seat frames.
Eric
Julian.P
#29 Re: In a Dither over Interior Trim Removal
Post by Julian.P » Fri Mar 10, 2017 5:45 pm
I wouldn't use 191 on fresh paint as it probably strip, it's ok on old paint paint if carefull and not left to soak, we use old towels one with cleaner another for drying the surface, try in a inconspicuous area first, another product is Huttons D'Solve its less aggressive than 191 and ok on painted surfaces however takes a little longer at removing adhesive, we use Evo stik products on a variety of coverings, carpets, vinyl's, vinyl flooring, leather and laminate's with no issues.
Hope this was of some help, Julian.
#30 Re: In a Dither over Interior Trim Removal
Post by mgcjag » Fri Mar 10, 2017 6:18 pm
Hi Julian...evostik maka a wide range of adhesives.....but dont be tempted to use there solvent impact on interior trim....even in there own technical spec they warn against useing it on vinyl they say that after several weeks the plasticiser in the vinyl will 'bleed' into the adhesive making it soft and sticky. The bond will then fail.
mark10337
Switzerland
#31 Re: In a Dither over Interior Trim Removal
Post by mark10337 » Mon Mar 13, 2017 9:19 pm
I can highly recommend dry ice blasting. You could clean the entire interior of adhesive residue in under 20 minutes with no nasty chemicals or scrubbing. I did the whole passenger footwell in 4 minutes. Comes off a treat.
There are a few mobile units around that will come round and do it for you, or drive it along to a local place that does it.
Dry ice blasting leaves no media in the car as it evaporates, leaving just the adhesive and dirt residue to brush or blast away with compressed air
-Mark
