Demister Vents
JulianBarratt
#21 Re: Demister Vents
Post by JulianBarratt » Mon Feb 03, 2020 9:00 am
Hi Geoff,
The two numbers i have quoted above are the straight type and the curved type - which covers both of the vent nozzles.
There is the actual vents themselves which are available as:
https://www.sngbarratt.com/uk/#!/Englis ... f2d101989f
but are (currently) quite expensive and available only as a set.
Hope this helps and i am not missing anything - do feel free to DM me if this doesnt cover what you are expecting.
MD at SNG Barratt Group
#22 Re: Demister Vents
Post by Gfhug » Mon Feb 03, 2020 11:29 am
Hi Julian, thank you for clarifying things. I was mistaken in thinking there is one long central vent nozzle not two straight ones together. My mistake, sorry.
Now we've got to persuade you to make the linked vent set a little less expensive :bigrin:
#23 Re: Demister Vents
Post by mgcjag » Mon Feb 03, 2020 11:36 am
Hi Geoff... :bigrin: or convince you to pay a bit more :bigrin: Steve
drichards
#24 Re: Demister Vents
Post by drichards » Tue Feb 11, 2020 11:33 pm
I had some reversed engineered and 3D printed using ABS-M30, yet to fit them so fingers crossed. Also made them slightly thicker as ones I have seen were very brittle. Not cheap but we all do daft things at times!
Danny Lee
#25 Re: Demister Vents
Post by Danny Lee » Fri Aug 29, 2025 12:50 am
Hi there
I’d use your name but don’t know it
I see you have reverse engineering of the vents …. Did it work well?
Are you prepared to make the cad files available so I can also make form ….. mine are totally unserviceable….OR can you make me a set for reasonable $’s
I see no benefit in doing the same job over
Danny Lee 0412327197 Melbourne
Boris64
#26 Re: Demister Vents
Post by Boris64 » Sat Aug 30, 2025 10:27 am
+1…
S1 Nov 61 FHC
alunwill
#27 Re: Demister Vents
Post by alunwill » Sat Aug 30, 2025 11:51 am
+1 also
Al
Series 1, 2+2
undergoing renovation
