New Developments In Rear Crank Sealing
#21 Re: New Developments In Rear Crank Sealing
Post by Gfhug » Sat Dec 07, 2024 6:33 pm
Steve, “acceptable weepage”? :bigrin:
As stated by a senior Rolls Royce engineer to a disgruntled American owner when he complained about oil weeping from the engine.
#22 Re: New Developments In Rear Crank Sealing
Post by mgcjag » Sat Dec 07, 2024 6:48 pm
Hi Geoff...yes but that's what a correctly fitted rope seal does...and it dosnt cost £300 for the seal and around £300 odd to have the crank groung to fit....Steve
#23 Re: New Developments In Rear Crank Sealing
Post by Gfhug » Sat Dec 07, 2024 6:51 pm
Ok Steve, so long as you promise to visit and correctly fit the rope seal for me :lol:
The alternate is that Rory will do all the work of fitting this new wonderful seal for me :wink:
#24 Re: New Developments In Rear Crank Sealing
Post by mgcjag » Sat Dec 07, 2024 7:05 pm
Typically a leak at the rear is the rear sump seal...which does need care when fitting...Steve
caveman
#25 Re: New Developments In Rear Crank Sealing
Post by caveman » Sat Dec 07, 2024 9:49 pm
:yeahthat:
1965 S1 4.2 FHC (early)
:wavegreatbritain:
frank77
#26 Re: New Developments In Rear Crank Sealing
Post by frank77 » Sat Jan 10, 2026 3:47 pm
Hi all,
just wanted to know if anyone has fitted the flexi-seal" from Rob Beere and is happy with it?
Frank
Frank
1969 S2 FHC
1964 AH 3000 MK3
#27 Re: New Developments In Rear Crank Sealing
Post by Gfhug » Sat Jan 10, 2026 4:12 pm
E600 wrote:
Fri Nov 22, 2024 12:46 am
Just completed my engine build using the stretch seal, will give an update as to its performance in due course
Hello Pat, any comments on the new seal, yet?
#28 Re: New Developments In Rear Crank Sealing
Post by mgcjag » Sat Jan 10, 2026 4:25 pm
Chris in post 19 above said Fitted one in March 2023. 3000 miles since fitting and just get the occassional drop on the garage floor. :shrug:
