Gaz shockers best or basic setting to start off with
#21 Re: Gaz shockers best or basic setting to start off with
Post by mgcjag » Thu Nov 05, 2020 4:10 pm
It will depend on what device your useing....abive was a tablet...this is a mobile.....
Joes66
#22 Re: Gaz shockers best or basic setting to start off with
Post by Joes66 » Thu Nov 05, 2020 5:57 pm
Yup
Thats what i have
But no add image at the bottom left
Joe
1969 series 2 2+2
Joes66
#23 Re: Gaz shockers best or basic setting to start off with
Post by Joes66 » Thu Nov 05, 2020 5:59 pm
I have options and attachments where you have add image
1969 series 2 2+2
#24 Re: Gaz shockers best or basic setting to start off with
Post by mgcjag » Thu Nov 05, 2020 6:09 pm
Jasper013
#25 Re: Gaz shockers best or basic setting to start off with
Post by Jasper013 » Sun Nov 08, 2020 10:24 pm
I recently purchased a set of rear Gaz Adjustable shocks and the recommended Gas springs from SNG.
I asked for advice regards how to set them initially.
Was told to have the spring platform raised to 100mm from the bottom of the shock and to turn the rebound adjuster 4 or 5 clicks.
This should give a good starting point in terms of ride height and ride quality.
Will be fitting my new kit at some point over the winter and will use these settings. Will feedback in due course.
'67 S1.5 OTS
Joes66
#26 Re: Gaz shockers best or basic setting to start off with
Post by Joes66 » Mon Nov 09, 2020 3:04 pm
Hiya
I have set mine to 4 clicks as well
Seems about right
Thats roughly where my spring platforms are set
Steve, I've tried to get the picture tab up but can't seem to do it
Will try my desktop
Otherwise I can send you some pics via e mail
Or actually I can also WhatsApp you them
Car is sitting fine other than slightly higher on the drivers side
Don't know why but may adjust it down half an inch that side
Maybe its because its a 2+2?
With the extra weight?
Joe
1969 series 2 2+2
