Manual Box with 2.88 Rear Axle
lestere
#21 Re: Manual Box with 2.88 Rear Axle
Post by lestere » Wed Aug 11, 2021 9:09 pm
Hi Keith.
I can’t recall having to use first around town other than to pull away. Forth gear is responsive and smooth from 30mph. If your car pulls like you say in second, I can’t see you having a problem either.
I changed the complete differential in its case, so it was an easy task. The 2.88:1 diff is much easier to find than the 3.08 (and cheaper) too. I had a removed the rear subframe to overhaul the rear suspension so to me it was the ideal opportunity. Good luck.
Lester
1966 Series 1. 2+2 Willow Green
#22 Re: Manual Box with 2.88 Rear Axle
Post by politeperson » Thu Aug 12, 2021 7:33 am
I have never found hill starts to be an issue with a 2.88, not even in the black mountains.
Fspp369
#23 Re: Manual Box with 2.88 Rear Axle
Post by Fspp369 » Thu Aug 12, 2021 4:55 pm
Nigel
I have a v12 HE efi with a four speed and O/D box and a 2.88 diff.....it’s great, any speed you like, any revs you like, smooth but at mid to high revs perhaps a v slight whine, but that’s about it.
Currently though thinking of going down the auto box route due to skeletal problems. The 2.88 will stay!
Although just at the moment as you may notice it’s not quite roadworthy ...
Just finished off my rotisserie,(the straps have gone)...proper legs and castors now!
Tee Hee!
Peter {XKE V12HE efi}
XKRS
Octavia VRS.
#24 Re: Manual Box with 2.88 Rear Axle
Post by PeterCrespin » Thu Aug 12, 2021 6:28 pm
Keith G wrote:
Wed Aug 11, 2021 8:36 pm
Having said that, I live near Macclesfield, so hill starts do arise!
A few runs from Jenkin's Chapel to Pym Chair will bed your transmission in nicely...
I had three years of regular tips from home in Buxton to a major client in Bollington. Range Rover across country, or motorbike on the Cat & Fiddle road (before they installed the cameras). Decisions, decisions.
Keith G
#25 Re: Manual Box with 2.88 Rear Axle
Post by Keith G » Mon Aug 16, 2021 11:01 pm
Thanks all for your very interesting viewpoints. I read that a 2.88 final drive is OK with a wide-ratio box, prefixed KE or KJ as fitted to Series 2 cars, but maybe too tall for a close ratio EJ box as found on a Series 1. My car is a series 1.5 with an EE gearbox! Turns out the EE was the first of the wide-ratio boxes fitted from Oct '67 to March '68, with 2.933:1 in first, so my car should be fine with a 2.88 diff. Another job for the coming winter! Thanks everyone for all the help and advice.
Keith G
1968 S1.5 OTS
