Clutch master cylinder
Iansparky
#21 Re: Clutch master cylinder
Post by Iansparky » Mon May 11, 2026 4:34 pm
I would look at removing the pedal box, its way easier on the bench, especially as the rod length will need setting
Ian
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
JerryL770
#22 Re: Clutch master cylinder
Post by JerryL770 » Thu May 28, 2026 3:58 am
mmmm. I see that the Demontweeks Willwood item has 3 cylinder bore diameters available.
SNGB items do not specify the cylinder bore. It would be good to know the diameter needed.
Does not seem to be info in the manuals (??)
Jerome Lunt
Iansparky
#23 Re: Clutch master cylinder
Post by Iansparky » Thu May 28, 2026 5:07 pm
It's 3/4 of an inch, 0.750
1965 series 1 ots
2016 Caddy van
