Mangoletsi throttle pedal assembly
Hotrod
#21 Re: Mangoletsi throttle pedal assembly
Post by Hotrod » Thu Mar 14, 2024 1:33 pm
Thanks David. Excellent suggestion.
Rod Evans
1969 S2 DHC LHD
NY5Angels
#22 Re: Mangoletsi throttle pedal assembly
Post by NY5Angels » Fri Sep 06, 2024 5:40 pm
Great. Six months before I finally get my dream car, the most worthwhile upgrade is no longer sold. I definitely notice issues with the throttle. It’s heavy and inconsistent.
#23 Re: Mangoletsi throttle pedal assembly
Post by bitsobrits » Sat Sep 07, 2024 12:57 am
LHD cars are so much worse than RHD (which seem fine to me on the two I've driven) because there are so many friction points and directional changes between the pedal and carbs. Not to mention the inverse ratio aspect of the two part LHD pedal floor mount pedal.
You can do your own cable throttle conversion without too much trouble if you are a somewhat skilled fabricator. The largest benefit will come by replacing LH vertical and cross rod, but for maximum smoothness you will want to also eliminate the pivot at the firewall behind the manifold. Or just adjust the stock linkage as best you can and keep it well lubed and grumble a bit every time you drive.
#24 Re: Mangoletsi throttle pedal assembly
Post by Gfhug » Sat Sep 07, 2024 8:08 am
And smile a lot every time you drive :bigrin:
NY5Angels
#25 Re: Mangoletsi throttle pedal assembly
Post by NY5Angels » Tue Dec 24, 2024 4:51 pm
Any headway on this? I’d love to purchase a Mangoletsi or replica kit.
sulzeruk wrote:
Fri Jan 12, 2024 11:57 am
I'll maybe look into making something as there is definitely a market for it and my mate has a CNC company with a nice new machine. Also has access to laser cutting as well.
