[edited] Spin on oil filter vs retrofitting OEM filter housing on Series 1
paydase
#61 Re: [edited] Spin on oil filter vs retrofitting OEM filter housing on Series 1
Post by paydase » Fri Jun 04, 2021 10:31 am
I see and I am now puzzled.
On the factory fit there are indeed two pictures showing the bottom plate on the filter housing.
This one for the 3.8:
factory fit housing 3.8.jpg (154.97 KiB) Viewed 4067 times
And that one for the 4.2:
factory fit housing 4.2.jpg (174.79 KiB) Viewed 4067 times
And this is the filter housing I found out when I removed the spin on device:
P1190120 (2).jpg (227.84 KiB) Viewed 4064 times
So should I understand that my filter housing is not a 3.8 one and instead is a 4.2 one with a removeable plate that I would have to source and install or is it a 3.8 one that was butchered?
And if a 3.8 one could I adapt a 4.2 plate on it?
Serge
1964 (3.8) FHC
1961 OTS
tinworm
#62 Re: [edited] Spin on oil filter vs retrofitting OEM filter housing on Series 1
Post by tinworm » Fri Jun 04, 2021 12:00 pm
Hello Serge, you have the correct 3.8 filter head just missing the plate. I cannot say how effective (or not) your spin on filter was as I do not know its method of attachment. I will have a look later and see if I have a 4.2 plate to compare with a 3.8 one I know I have in storage.
Barrie
paydase
#63 Re: [edited] Spin on oil filter vs retrofitting OEM filter housing on Series 1
Post by paydase » Fri Jun 04, 2021 12:59 pm
Many thanks Barrie,
If you have a spare plate, that would be most appreciated.
If not and difficult to find, I will have to machine such a plate from sheet metal, hoping that it can be inserted and fit in the assembly.
Although I may look at my filter housing dimensions, exact dimensions of the plate (outside and inside diameters, thickness) would be very useful
Serge
1964 (3.8) FHC
1961 OTS
tinworm
#64 Re: [edited] Spin on oil filter vs retrofitting OEM filter housing on Series 1
Post by tinworm » Fri Jun 04, 2021 1:17 pm
Hello Serge, the photo below shows the different valve housings 3.8, 4.2 (mk2 item not E-type but the plate is the same ) and 4.2 S2 .
The 4.2 has a smaller hole than the 3.8 and could be easily put in a lathe and machined out to match your housing (it would be a press fit so you would need to turn up a fitting tool out of a piece of pipe and you will need a press of some sort)
The dimensions of the 3.8 one are as follows - Diameter 71.5mm
Hole 32.2mm (you would need to adjust to suit)
Material 1mm mild steel and its flat (not concave/convex)
You can make one from scratch quite easily once pressed on the alloy would need to be staked to hold it firmly in position .
The S2 valve block is scrap and you are welcome to it if you want to go that route.
Barrie
paydase
#65 Re: [edited] Spin on oil filter vs retrofitting OEM filter housing on Series 1
Post by paydase » Fri Jun 04, 2021 2:38 pm
Thank you very much for the infos and measurements, Barrie.
I will try to machine that plate accordingly.
Thank you also for the S2 block offer, I don't think I will need it but in case I keep it in mind.
Serge
1964 (3.8) FHC
1961 OTS
tinworm
#66 Re: [edited] Spin on oil filter vs retrofitting OEM filter housing on Series 1
Post by tinworm » Fri Jun 04, 2021 4:49 pm
Glad to be of help Serge. Let us know how it goes.
Barrie
DHillman
#67 Re: [edited] Spin on oil filter vs retrofitting OEM filter housing on Series 1
Post by DHillman » Mon Apr 18, 2022 3:13 am
Serge,
Any suggestions for how to remove the anchor bolt so I can install a spin on filter?
Thanks,
David
paydase
#68 Re: [edited] Spin on oil filter vs retrofitting OEM filter housing on Series 1
Post by paydase » Mon Apr 18, 2022 3:33 pm
Hi David,
What do you mean by anchor bolt: the long bolt that holds and attaches the canister to the filter housing?
If so, best is to first remove the air filter box to get sufficient space to work on the oil filter
Serge
1964 (3.8) FHC
1961 OTS
tinworm
#69 Re: [edited] Spin on oil filter vs retrofitting OEM filter housing on Series 1
Post by tinworm » Mon Apr 18, 2022 4:26 pm
I hope the 'anchor bolt' is not the centre boss - as that is part of the casting on a 3.8. I have a 3.8 casting that someone had tried to remove said part with some stilsons and ruined the entire thing. The 4.2 centre boss will come out OK as it is a separate part.
Barrie
