Engine number
Bernie2015
#1 Engine number
Post by Bernie2015 » Tue Jan 10, 2017 4:49 pm
Im just fillling in the dreaded V55/5 to register my 1969 USA 2+2 and am trying to locate the engine number. I believe it should be on the bell housing flange. The only numbers on there are what looks like 71 66878. Does that make sense to anyone as it doesn't match whats on the ID plate 7R 360889 and it should start with a 3 according to the year of the car. HELP!!!
Bernie 1966 S1 OTS
#2 Re: Engine number
Post by Gfhug » Tue Jan 10, 2017 5:05 pm
Bernie, please post a photo, that'll allow people to recognise what you are looking at with that 66878 number
Bernie2015
#3 Re: Engine number
Post by Bernie2015 » Tue Jan 10, 2017 5:16 pm
Bernie 1966 S1 OTS
Red Kite
#4 Re: Engine number
Post by Red Kite » Tue Jan 10, 2017 5:21 pm
I think 7L is an XJ6 prefix.
Gerry.
S2 FHC 1R20003
#5 Re: Engine number
Post by mgcjag » Tue Jan 10, 2017 5:35 pm
Hi Bernie..as above xj6 number...have a look here http://www.jag-lovers.org/xk-lovers/lib ... umbers.htm
Bernie2015
#6 Re: Engine number
Post by Bernie2015 » Tue Jan 10, 2017 5:47 pm
Thanks all will look into it
Bernie 1966 S1 OTS
#7 Re: Engine number
Post by christopher storey » Wed Jan 11, 2017 10:02 am
Bernie : it's a common swap - don't worry about it - just put 7L 66878 on the form or if you can read the suffix ( I can't from the photograph ) which probably will be H, S or L put that on at the end as well
Bernie2015
#8 Re: Engine number
Post by Bernie2015 » Thu Jan 12, 2017 7:35 am
Thanks will do
Bernie 1966 S1 OTS
#9 Re: Engine number
Post by PeterCrespin » Sat Jan 14, 2017 6:50 pm
Suffix is L (7:1 'emissions' CR). So unless it has been fitted with N (8:1) or H (9:1) pistons it won't be winning any drag races...
