Principal Hood Anchorage/Pivot point please ?
rfs1957
#1 Principal Hood Anchorage/Pivot point please ?
Post by rfs1957 » Mon Jan 30, 2017 8:17 pm
Something tells me that an apparently 1/4 UNC chromed bolt with a bit of copper pipe and a swathe of washers is probably NOT the way that this is meant to be fastened.
More PO botches ?
The thread in the body will be nasty, so can I tap it out to 5/16 UNF or should I helicoil it back to 1/4 ? If anyone can tell me what the appearance and order of the pivot-bolt and bits should look like I'd be very grateful.
Tbob
#2 Re: Principal Hood Anchorage/Pivot point please ?
Post by Tbob » Mon Jan 30, 2017 9:51 pm
It takes a chrome-plated shoulder bolt 1/4 - 28 thread with a dome head, and a brass washer. I can post a pic if you need one.
FWIW, I had to substitute a setup similar to what you show, because the support stick was binding on the side panel.
Bob t
LHD '69 OTS. (Former) basket case
rfs1957
#3 Re: Principal Hood Anchorage/Pivot point please ?
Post by rfs1957 » Tue Jan 31, 2017 8:33 am
Thanks Bob, It looks like bolt BD19160 is the right one
http://www.sngbarratt.com/PartSearchRes ... no=BD19160
- it looks to have a parallel section which is way longer than the thickness of the side-stick is thick, is the spacer to obtain the clearance with the side-cheek actually more of a sleeve ?
ETTony
#4 Re: Principal Hood Anchorage/Pivot point please ?
Post by ETTony » Sat Feb 04, 2017 9:50 pm
rfs1957 wrote:Thanks Bob, It looks like bolt BD19160 is the right one
This one looks like the top hinge bolt at the top of the B pillar.
Not the one for the single frame arm on the panel.
The one you need is BD19393 Hoodframe bolt chrom £7.40 ea
:rvrence:
Tony in Devon
rfs1957
#5 Re: Principal Hood Anchorage/Pivot point please ?
Post by rfs1957 » Sat Feb 04, 2017 10:09 pm
Indeed that DOES look more like what I was expecting, with a shoulder, presumably 5/16", to carry the lower end of that pivoting side arm where it fastens to the car body to either side of the seats.
So it tightens up hard and leaves a parallel shank to carry the strut, right ?
Wonder why is it referred to as "Rear Quarter Top Arm Chrome Bolt" on the SNGB site then ?
You must be correct Tony, as in J.30 (for the non-initiated, and not long that included me, J.30 is what we refer to the Parts Book as when we want to sound smart, which now includes me) it calls it - appositely - Bolt, Special, securing Control Link to Body.
Many thanks, that's one less wrong-part-ordered.
ETTony
#6 Re: Principal Hood Anchorage/Pivot point please ?
Post by ETTony » Sun Feb 05, 2017 1:43 pm
rfs1957 wrote:Indeed that DOES look more like what I was expecting, with a shoulder, presumably 5/16", to carry the lower end of that pivoting side arm where it fastens to the car body to either side of the seats.
No dramas Rory, i had been looking out for the #???? For six months, then tripped over it it looking for something else, as we do. :salute:
The thought of buying a set of hood bolts, for one damn bolt was not going to happen.
I now know that **G do not have every nut and bolt online.
Tony in Devon
