Substitute handbrake switch please ?
rfs1957
#1 Substitute handbrake switch please ?
Post by rfs1957 » Sat Feb 11, 2017 9:36 pm
I must be very dumb as can't see how to search for "handbrake AND switch" at the same time on the search engine, yet I am sure this has been treated here a million times already ...............
The switch and its bracket are not my favourite parts on the car and I'd like to fit something else - can anyone guide me to pictures and links to a suitable switch, and inspiration of how and where to mount it ?
Many thanks.
PS anyone found a suitable Clevis Pin with an arm or leg that will clip over behind the cable, and thus obviate the need for a split-pin on the back-side of the handbrake-cable anchorage in the cabin ? Or do I have to make one ?! It would be so much easier when getting the centre console out and needing to get the handbrake lever more vertical for extraction purposes.
#2 Re: Substitute handbrake switch please ?
Post by abowie » Sat Feb 11, 2017 10:24 pm
You could use any switch that fits in the space. You'd just need to make up a bracket to fit.
I sort of did this the other way around; I had the switch buy not the bracket so I had to make one.
http://www.projectetype.com/index.php/t ... 18737.html
