Number plates
Bernie2015
#1 Number plates
Post by Bernie2015 » Tue Feb 21, 2017 10:12 am
Hi all,
can anyone suggest a place to get an embossed rear number plate for a series 2?
Bernie 1966 S1 OTS
Simon P
#2 Re: Number plates
Post by Simon P » Tue Feb 21, 2017 10:18 am
Try Framptons. Very good:
http://www.framptonsplates.com/
1969 S2 FHC - 1R20258
2008 Caterham Seven Roadsport
#3 Re: Number plates
Post by mgcjag » Tue Feb 21, 2017 10:21 am
Hi Bernie...just look at the similar topics below...lots of info there
Bernie2015
#4 Re: Number plates
Post by Bernie2015 » Tue Feb 21, 2017 10:54 am
Thanks for the quick reply, do you know what size is standard for a series 2 rear plate - Framptons not sure?
Bernie 1966 S1 OTS
Red Kite
#5 Re: Number plates
Post by Red Kite » Tue Feb 21, 2017 11:28 am
You can get a number of different sizes.
Mine are from Tippers Plates and are 9 and 1/2ins wide x 8 and 3/8ins high but this works for 3 numbers and 3 digits.
If you have a 3 letter, 3 number plus suffix then it will not be wide enough.
Gerry.
S2 FHC 1R20003
#6 Re: Number plates
Post by mgcjag » Tue Feb 21, 2017 12:07 pm
Hi Bernie...mine with a suffix letter.....12in wide 8 3/8 high
#7 Re: Number plates
Post by Gfhug » Tue Feb 21, 2017 12:24 pm
Bernie, if you look at the topic 'Series 2 Aesthetics' you'll see quite a bit of comment about changing the rear lights to those from forum member MarekH, then you can ditch the reverse lights, fit an oblong not square number plate and fit the straight S1 tailpipes. Those of us who have done it quite like the result.
viewtopic.php?f=5&t=3359
Just a thought to consider before buying your plates.
yev
#8 Re: Number plates
Post by yev » Tue Feb 21, 2017 3:39 pm
worked for me this way
#9 Re: Number plates
Post by politeperson » Tue Feb 21, 2017 5:05 pm
Yeah.
I bought this plate from Framptons.
Web Rear.jpg (123.69 KiB) Viewed 6023 times
Bernie2015
#10 Re: Number plates
Post by Bernie2015 » Wed Feb 22, 2017 9:18 am
Thanks all great advice as usual can't beat this website.
Bernie 1966 S1 OTS
