First start
andrewh
#1 First start
Post by andrewh » Mon Mar 06, 2017 5:56 pm
Nice one. Set the timing, put some oil in the dashpots and .....well
forgot to tighten up one of the cam feed banjos hence the smoke from the exhaust but all the rest good. Ahhhh there is nothing quite like a new build start followed by a much deserved glass of cool beer.
1962 3.8 Series One FHC
288gto
Russia
#2 Re: First start
Post by 288gto » Mon Mar 06, 2017 6:05 pm
:bouncyyellow: :drinkingcheers: :bouncyyellow:
JagWaugh
Switzerland
#3 Re: First start
Post by JagWaugh » Mon Mar 06, 2017 6:29 pm
Well done!
#4 Re: First start
Post by mgcjag » Mon Mar 06, 2017 6:38 pm
Fire....smoke..and a big bang.....sounds great....at least it started.......really like the camera woman..Andrew is it supposed to be doing that.... :bigrin:
andrewh
#5 Re: First start
Post by andrewh » Mon Mar 06, 2017 6:46 pm
Thanks chaps. Yes it was all good. I didnt tighten the bottom feed pipe, not the banjo actually, and this poured onto the exhaust so hence the smoke which the missus was not expecting. Other than that all good Am getting the ammeter moving to C when switched ignition on and at start to Discharge . Presume I have the ammeter wires the wrong way around! Cannot recall seeing any ID marks on the Ammeter terminals. Anyway, engine showing great oil pressure and sounds lovely, so very happy.
Nickleback
#6 Re: First start
Post by Nickleback » Mon Mar 06, 2017 7:13 pm
Congrats Andrew, cant believe you have done it so quickly ! :bouncyyellow: :drinkingcheers: :dance: :rvrence:
Mike,
1970 S2 FHC 2R28165
Mark Gordon
#7 Re: First start
Post by Mark Gordon » Mon Mar 06, 2017 7:25 pm
Well done, Andrew. I just looks like you forgot to properly torque one of the fittings on the lucas smoke distribution system. :wink:
#8 Re: First start
Post by politeperson » Mon Mar 06, 2017 8:56 pm
Excellent.
Moments like this are what you were put on this planet for.
ralphr1780
#9 Re: First start
Post by ralphr1780 » Mon Mar 06, 2017 9:43 pm
A great moment Andrew :bouncyyellow:
Congrats, well deserved :drinkingcheers:
I also had forgotten to tighten the cam oil feed banjo, but I had cranked few times before connecting fuel and ignition just to get the oil circulating and some oil pressure. Got a nice poodle of oil on the garage floor. :banghead:
Ralph
'69 OTS + '62 OTS - Belgium
andrewh
#10 Re: First start
Post by andrewh » Mon Mar 06, 2017 9:49 pm
thanks Ralph. I had done exactly the same as you before going for the start. The smoke was the oil on the exhaust that I had not wiped off from the cranking tests. I had tightened the lower banjo prior to start up. I had checked the oil pressure before going for the start for obvious reasons. I am very pleased though, lots still to do , but it has a beating heart now.
JagWaugh
Switzerland
#11 Re: First start
Post by JagWaugh » Tue Mar 07, 2017 6:07 am
andrewh wrote:Am getting the ammeter moving to C when switched ignition on and at start to Discharge . Presume I have the ammeter wires the wrong way around! Cannot recall seeing any ID marks on the Ammeter terminals. Anyway, engine showing great oil pressure and sounds lovely, so very happy.
If your ammeter is showing backwards, but otherwise correct, values, then you've most probably got the wires reversed at the ammeter. This is one of the things that you need to change if you convert from + to - earth (although you don't _need_ to change it, it has no bearing on the function of anything).
andrewh
#12 Re: First start
Post by andrewh » Tue Mar 07, 2017 9:14 am
yes I guess they are the wrong way around, although cannot recall seeing any markings on the back of the ammeter. Will take a look and see what what , thanks
#13 Re: First start
Post by malcolm » Tue Mar 07, 2017 10:01 am
Well done you! Mine's been away for a while, I might be collecting today. More later!
