Oil filter assembly
Tjclare
#1 Oil filter assembly
Post by Tjclare » Fri Mar 17, 2017 2:59 pm
Hi I was wondering if anybody could help me. I am assembling my engine ( series 2 4.2) and when I have looked inside the assembly there is what seems to be a pressure valve loose inside the houseing.
It appears it is a push fit into one of the holes I was just wondering if this is correct and which hole should be in and also which way round
Thanks in advance Tony
#2 Re: Oil filter assembly
Post by mgcjag » Fri Mar 17, 2017 3:56 pm
Hi Tony...this may help.....also try a search there is more info viewtopic.php?f=3&t=6122&p=79321&hilit= ... lve#p79321
Tjclare
#3 Re: Oil filter assembly
Post by Tjclare » Fri Mar 17, 2017 6:22 pm
Thank you so much Steve much appreciated
