Wiper parking LHD/RHD
Hugo
#1 Wiper parking LHD/RHD
Post by Hugo » Mon Apr 10, 2017 11:12 pm
I have just been reading Mike Cassidy's splendid treatise on converting a LHD car to RHD. He expresses surprise that Lucas went to the trouble of providing two positions for the parking cam (Series II) 180 degreeas apart on the drive gear, when all you have to do is rotate the operating lever 180 deg on the output shaft.
The answer is simple - most cars using this type of wiper motor had a rack-and-pinion linkage, rather than the rod linkage of the E-Type. The only other way to reverse the park position with a rack-and-pinion is to turn the wheel-boxes upside down, which in most cases is not feasible. Hence the two-position cam. More nerdy stuff I'm afraid!
johnetype
#2 Re: Wiper parking LHD/RHD
Post by johnetype » Thu Apr 13, 2017 1:40 pm
and a second for Mike's excellent guide but another piece of nerdiness missed out is that you should change the two outer wheel-boxes over as they are handed. More precisely, they have their ball joints at different pivot points but are easy to swap over.
1969 Series 2 FHC
dal2.0litrefrogeye
#3 Re: Wiper parking LHD/RHD
Post by dal2.0litrefrogeye » Tue Apr 18, 2017 1:52 pm
Can someone point me in the right direction to Mike s post please
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
#4 Re: Wiper parking LHD/RHD
Post by mgcjag » Tue Apr 18, 2017 3:27 pm
Knowledge base / technical/ Mike Cassidy lhd,rhd conversion
dal2.0litrefrogeye
#5 Re: Wiper parking LHD/RHD
Post by dal2.0litrefrogeye » Wed Apr 19, 2017 9:20 am
