Where to buy grease nipples?
Jasper013
#1 Where to buy grease nipples?
Post by Jasper013 » Thu Apr 20, 2017 8:16 pm
Not available on the SNG website.
Not sure of size(?)
Any help on where to source grease nipples gratefully received.
Have a broken one on a tie rod but would like to pick up a few - straight/45/90
Thanks :bigrin:
'67 S1.5 OTS
#2 Re: Where to buy grease nipples?
Post by mgcjag » Thu Apr 20, 2017 8:46 pm
Hi Paul...local car, engineering, tractor, lawnmower tyoe places should have them...or on the SNG site look up the part the nipple is from...eg track rod end http://www.sngbarratt.com/ProductDetail ... 3312d0&l=7
#3 Re: Where to buy grease nipples?
Post by chrisfell » Thu Apr 20, 2017 9:18 pm
Gird your loins and venture into the evil that is eBay. You'll find more choose than you knew existed. Check the size you need, could be 1/4" bsf or maybe 5/16" bsf. Or a PO may have fitted a metric version.
Jasper013
#4 Re: Where to buy grease nipples?
Post by Jasper013 » Thu Apr 20, 2017 9:28 pm
Thanks chaps.
Should sort me out.
'67 S1.5 OTS
norman m. macleod
#5 Re: Where to buy grease nipples?
Post by norman m. macleod » Fri Apr 21, 2017 4:23 am
Hi Jasper,
The correct Jaguar Part No for these nipples is C3044/1. They are 1/4" x 28 TPI to conform to SAE zerk standards. Regrettably, if you order these from SNG, they will supply 1/8" BSP nipples, which have a major diameter of 0.383", and do not fit anywhere on an E-Type that I know of. I have notified them of this error on at least 3 occasions over 6 or so years, but no action evident...... :roll: :roll:
To complicate the issue, there are nipples made with BSP threads (also 28 TPI), so be wary. My advice would be to source from EBay or similar, straight/90 deg/45 deg are available.....
Kind regards,
Norman :Scotland:
1967 S1 2+2
norman m. macleod
#6 Re: Where to buy grease nipples?
Post by norman m. macleod » Fri Apr 21, 2017 4:34 am
Hi again Jasper,
Corrections.....First line should read 1/4" x 28TPI UNF........
Second last line should read BSF threads (also 28 TPI)........ :oops:
Kind regards,
Norman :Scotland:
1967 S1 2+2
Jasper013
#7 Re: Where to buy grease nipples?
Post by Jasper013 » Fri Apr 21, 2017 5:48 pm
Thanks Norman.
With those details to hand I will take a look on e-bay.
Many thanks.
'67 S1.5 OTS
Jasper013
#8 Re: Where to buy grease nipples?
Post by Jasper013 » Fri Apr 21, 2017 5:59 pm
Sorted.
Well ordered at least!
'67 S1.5 OTS
