disaster123
Post
by disaster123 » Fri Jul 21, 2017 8:20 pm
Hello,
i'm searching for covers for the leather at the doors.
Picture:
Thanks!
Greets,
Stefan
Jaguar E-Type S3 1971
VW Käfer 1200 1967
MG MGB 1967
JJC
Post
by JJC » Sat Aug 19, 2017 11:32 pm
Actually, they are vinyl . Any upholstery shop will have a selection. No worries.
disaster123
Post
by disaster123 » Sun Aug 20, 2017 5:49 am
Thanks - but how does it originally look like? Do you have a photo?
VW Käfer 1200 1967
MG MGB 1967
- Moderator
Post
by mgcjag » Sun Aug 20, 2017 8:21 am
Hi Stefan.....is this what you are looking for this is fron my S2 not sure it its the same for a S3..i can see that it looks like you have trimmed useing leather which is quite thick and with the trim covering it could make the doors too tight to close..the trim in the photo with the herringbone patern is i think unavailable but there are other similar versions
Edit...for some reason i think the trim on the S3 had a more furry look
JJC
Post
by JJC » Sun Aug 20, 2017 10:30 am
I would try XK's Unlimited in California. 800 444 5247. Ask for Steve. Knowledgeable guy. .
Post
by christopher storey » Sun Aug 20, 2017 9:40 pm
JJC wrote:I would try XK's Unlimited in California. 800 444 5247. Ask for Steve. Knowledgeable guy. .
Not, I'm afraid, a very convenient supplier for Germany
disaster123
Post
by disaster123 » Mon Aug 21, 2017 5:18 pm
Thanks Simon. Do you know which type i need for the S3 and which color matches the jaguar beige / cinnamon.
VW Käfer 1200 1967
MG MGB 1967
disaster123
Post
by disaster123 » Wed Aug 23, 2017 11:14 am
Do i need 264-BG or 235-BG?
VW Käfer 1200 1967
MG MGB 1967
- Moderator
Post
by mgcjag » Wed Aug 23, 2017 11:29 am
Neither...they are the wrong thing.....as they also have a rubber seal part attached....the best thing to do is contact one of the trimmers.. BAS ..Aldridge.... etc....and get them to send samples....either the vinyl type or the furry one....they will know what type your car should have....or you can send a sample of your colour so they can get the closest match
You need something like this called edge trims
http://www.woolies-trim.co.uk/c-329-clo ... -trim.aspx
http://www.woolies-trim.co.uk/c-330-pvc-edge-trims.aspx
disaster123
Post
by disaster123 » Wed Aug 23, 2017 12:01 pm
Thanks!
VW Käfer 1200 1967
MG MGB 1967
Simon P
Post
by Simon P » Wed Aug 23, 2017 12:38 pm
mgcjag wrote:Neither...they are the wrong thing.....as they also have a rubber seal part attached
How bizarre! I thought I'd originally cut and pasted the same link as you - hence the accompanying text. Link now edited. Most odd.....
1969 S2 FHC - 1R20258
2008 Caterham Seven Roadsport
