headlight failure
jonhall88
#1 headlight failure
Post by jonhall88 » Wed Sep 13, 2017 11:11 am
Okay before I go into the realms of fantasy, my headlights are not working on dipped beam, sides and full beam are fine as are the tail lights so
1. check bulbs (would it be normal for both to fail at same time)
2, check fuses (not sure if single fuse supplies all)
3 check dash switch ( if power going to headlights where is the relay ? )
ok not rocket science but as its pouring with rain a little pre help always comes in handy
made myself pretty unpopular at goodwood when I explained to ser 1 and 2 owners why the ser 3 is a far superior car (having owned ser 1 ) and have use of sons ser 2 and 99 percent of earlier car owners have never driven a 3, don't get me wrong not dissing the 1 and 2 but the 3 was natural progression
1974 ser 3
#2 Re: headlight failure
Post by Series1 Stu » Wed Sep 13, 2017 7:51 pm
According to my wiring diagram it seems that fuse 2 (35 amp) has blown. This protects only the low beam filaments so is the likely cause. However, the fuse will have blown for a reason so it might be wise to check the wiring etc. Although it could be that a bulb blew and took the fuse with it.
jonhall88
#3 Re: headlight failure
Post by jonhall88 » Wed Sep 13, 2017 8:11 pm
If it ever stops raining I will check the fuse and drop test the lighting circuits,
jin
1974 ser 3
#4 Re: headlight failure
Post by mgcjag » Wed Sep 13, 2017 8:21 pm
Hi John....your car is a S3 i assume.....do you have a wireing diagram...there,s one in the knowledge base section shows 19 as a 2 way fuse unit but that feeds both high and low beam, so you need to check connections..try to put your name and car model in as a signature.....Steve
Ikebaddog
#5 Re: headlight failure
Post by Ikebaddog » Thu Sep 14, 2017 7:45 am
jonhall88 wrote:Okay before I go into the realms of fantasy, my headlights are not working on dipped beam, sides and full beam are fine as are the tail lights so
Make sure you actually have Bulbs, just changed my sealed beam unit!!!! Haven't seen one of those since my dad changed one in his Viva!
The series 3 is better looking as well........ Don't you think?
S3 2+2 1971
MontanaDiver
#6 Re: headlight failure
Post by MontanaDiver » Thu Sep 14, 2017 5:41 pm
There are two fuses. One for the high beams and one for the dipped beam. They should be the top two fuses on the left side of the center gauge cluster. The turn signal switch powers the high beams when pulled towards the steering wheel.
I think the low beam is the second fuse. Check them with a meter or light to quickly determine if they work. The switch should be okay if you have high beams.
Sounds like a fuse or wiring issue.
Dennis
Dennis
74 E-type OTS 5.3 EFI HE Marelli V12 4 speed
1990 Jaguar XJS V12 convertible donor car
Great Falls, Montana
jonhall88
#7 Re: headlight failure
Post by jonhall88 » Thu Sep 14, 2017 11:24 pm
Thanks for all the helpful replies makes life much easier, still raining so will wait
car is a Jan 1974 ser 3 :bigrin:
1974 ser 3
