My 3.8 head has been into the machine shop and has had everything done to make it like new, however I now have the choice to fit any of the three cam types eg early, second grooved type or later XJ6.
Which one do I to go for ?
Best cam to use for normal road use
#2 Re: Best cam to use for normal road use
All Jag XK cams are the same performance onecthey went to 3/8" hrrls inecveryvgood
golfnut324
#3 Re: Best cam to use for normal road use
I'll have what he's having!PeterCrespin wrote:.......... onecthey went to 3/8" hrrls inecveryvgood
Craig
'68 E-Type FHC
'68 E-Type FHC
phil.dobson@mac.com
#4 Re: Best cam to use for normal road use
the best one is the one that came with it!
#5 Re: Best cam to use for normal road use
Lyons, there has been a lot of discussion about cams. Peter is correct. What is said about the later cams is they give a slighter quieter running engine. And for on the road, normal use, would you see any difference or benefit?
