Door hinges
johnj
#1 Door hinges
Post by johnj » Sun Dec 03, 2017 1:59 am
Re hanging my doors on the series 1 1/2 what are the 2 set screws on the hinges on door side for
Is it some factory alignment puzzled
Thanks in advance
Jeremy
#2 Re: Door hinges
Post by Jeremy » Sun Dec 17, 2017 4:06 pm
The safety strap is fixed on with 2 panhead screws. But AFAICR there are 4 holes so the same hinges can be used the other way up on the other side of the car. Might that be the answer?
Jeremy
1967 S1 4.2 FHC
64etype
#3 Re: Door hinges
Post by 64etype » Fri Dec 22, 2017 2:42 pm
I believe they were installed/drilled at the factory to help assure door alignment as the clamping force provided by the four set screws could be less than adequate. I found them to be very helpful with achieving alignment when reinstalling original doors and hinges.
Eric
