LHD/RHD conversion series 2 OTS
rubyfloriley
#1 LHD/RHD conversion series 2 OTS
Post by rubyfloriley » Sun Dec 03, 2017 9:46 pm
I have been searching for details or drawings or measurements of the alterations needed to the brake and clutch pedal arms when switching over to RHD. I have moved the pedal box over and it appears very little if any cranking is necessary, the throttle pedal position is fixed giving the available space for the brake and clutch pedals. In a previous post i saw reference to these dims as being found in the knowledge base can someone please point it out to me.
Also i cannot find the reference to factory finishes for various components i.e pedal shafts what colour and are they painted, ditto various brackets for horn and holding splash panels etc. sure ive seen it but cant find it again.
Thank you in anticipation.
Brian.
#2 Re: LHD/RHD conversion series 2 OTS
Post by abowie » Sun Dec 03, 2017 9:51 pm
There's a diagram of pedal alteration in the Cassidy series.
Pedals are painted satin black.
#3 Re: LHD/RHD conversion series 2 OTS
Post by mgcjag » Sun Dec 03, 2017 9:57 pm
Brian..have a look here.....10 part on conversion....about 3/4 of the way down viewtopic.php?f=16&t=700
rubyfloriley
#4 Re: LHD/RHD conversion series 2 OTS
Post by rubyfloriley » Mon Dec 04, 2017 10:25 pm
Thanks very much this is most helpful i will compare the dims given to what i have.
Brian.
rubyfloriley
#5 Re: LHD/RHD conversion series 2 OTS
Post by rubyfloriley » Fri Dec 08, 2017 11:04 pm
Hi does anyone know of a supplier of series 2 RHD steering column housing manufactured in alluminium all i have seen is composite ones. it bolts to the bulkhead. have tried Robeys and SNG they only have composite.
Brian.
Maxa
#6 Re: LHD/RHD conversion series 2 OTS
Post by Maxa » Sat Dec 09, 2017 1:56 pm
Hi Brian, I bought a bare casting from Ken Verity about a year ago from some leftover stock he had. It needed quite a bit of fettling but he may have some left. I think he trades as Series 1 Spares and Restoration.
Pm me if you can’t find his details.
With the number of left to right conversion bits he sells maybe Andy at Hutsons could commission some. Not original of course though. Hope this helps.
Mike.
rubyfloriley
#7 Re: LHD/RHD conversion series 2 OTS
Post by rubyfloriley » Sat Dec 09, 2017 2:36 pm
Thanks mike i will give him a try.
rubyfloriley
#8 Re: LHD/RHD conversion series 2 OTS
Post by rubyfloriley » Sun Dec 10, 2017 4:24 am
Thanks Mike Ken didn't have any left so may i repeat my post if anyone knows of a supply of aluminium steering column housings that bolts to the bulkhead for a RHD series 2. or if anyone is considering having a batch done please let me know.
Heronscourt
#9 Re: LHD/RHD conversion series 2 OTS
Post by Heronscourt » Wed May 12, 2021 9:09 pm
Did anyone find the alloy steering column housing referred to in this post. I’ve seen one at Jaguar spares day and they look so much more robust
Alan R
Etype series 1.5 roadster 1968
rubyfloriley
#10 Re: LHD/RHD conversion series 2 OTS
Post by rubyfloriley » Tue Oct 05, 2021 3:32 pm
Hello
did you find an ally housing i never did.
#11 Re: LHD/RHD conversion series 2 OTS
Post by mgcjag » Tue Oct 05, 2021 3:34 pm
Post in the wanted section....Steve
