Distributor Oil Seal
ALAN COCHRANE
#1 Distributor Oil Seal
Post by ALAN COCHRANE » Tue Jan 09, 2018 7:21 pm
Hi Everyone
Can anyone tell me the correct part number for the DMBZ6 oil seal that sits between the shaft and the engine block. The part I ordered from SNG had the number 418723 but clearly is not the right one.
Alan
Alan Cochrane
E-by'eck
#2 Re: Distributor Oil Seal
Post by E-by'eck » Tue Jan 09, 2018 8:39 pm
Might be worth trying Martin at Distributor Doctor Alan....did a great job renovating mine
http://www.distributordoctor.com/contact.php
Regards Graham
E type renovation .... 1962 3.8 Ser1 RHD DHC
If you're going through hell, keep going. ~Winston Churchill
#3 Re: Distributor Oil Seal
Post by abowie » Tue Jan 09, 2018 10:07 pm
If it's the square section cork seal, these often need a fair bit of fettling to get them to fit. I tend to use some sandpaper.
If yours has an o ring on the distributor shaft the best thing to do would be to go to a hydraulic seal/bearing supplier and match what you have.
#4 Re: Distributor Oil Seal
ALAN COCHRANE
#5 Re: Distributor Oil Seal
Post by ALAN COCHRANE » Wed Jan 10, 2018 12:06 pm
Andrew
Thanks for the info. I've already got the first seal-418723 and as you've said-"not right at all". The cork seal seems to be the one I'm after. The existing seal appears to be cork heavily impregnated with oil.
Alan
Alan Cochrane
