Length of Bolts N10-32 UNF
Durango2k
#1 Length of Bolts N10-32 UNF
Post by Durango2k » Fri Jan 19, 2018 4:42 pm
Hi all,
I asked Robey‘s for the correct bolts for the black headlamp bowls. Steve from MR kindly answered, he wrote it is N10 UNF.
Now, I can only guess that it means N10-32 UNF ?
If, then I found them on ebay germany:
https://www.ebay.de/itm/Sechskantschrau ... 6288b77390
They offer them in 3/8 length or 5/8 length. Which is correct ? (I can measure correct depth later if no one knows it).
Is a 6-flat (hexa) head fine ? Didn‘t they come “slotted“ ?
Carsten
288gto
Russia
#2 Re: Length of Bolts N10-32 UNF
Post by 288gto » Fri Jan 19, 2018 5:58 pm
Hi Carsten,
Do you mean the ones that fix the bowl to the car or the adjusters?
http://xks.com/i-23896652-screw-kit-hea ... -1603.html
Or
https://rover.ebay.com/rover/0/0/0?mpre ... 2280889343
Pics of both and both available in the links above.
If it's just the fixings, try searching for "10-32 unf slot head screws" or "10-32 unf pan head"
https://rover.ebay.com/rover/0/0/0?mpre ... 1406299683
Durango2k
#3 Re: Length of Bolts N10-32 UNF
Post by Durango2k » Sat Jan 20, 2018 8:42 am
Hi Simon,
It is just the fixings. I bought adjusters from SNG just to find mine on the day the new ones arrived. Maybe send them back to SNG to get 10 E back, together with some other „double“ or „wrong items“.
Many thanks for the links, the XKS item is certainly correct and looks better then the ebay ones, but I keep searching.
Do you have a name for these springs to allow me googling them as well ?
I believe that with the plastic inserts shown in your link above (lucas adjuster kit for classic mini etc) the bolts do not moove due to the grip the plastic nuts can give. My bowls both are fitted with original nuts and stainless cages...so I need the springs.
I thought I might otherwise buy „spring wire“ from ebay and bend me some myself...
Carsten
