Megasquirt 4.2 series 3 XJ6
ChrisCtype
#1 Megasquirt 4.2 series 3 XJ6
Post by ChrisCtype » Tue Jan 23, 2018 7:04 pm
Hopefully there might be others out there, Ive not asked before but thought its worth a try
I'm building a Realm C type replica using a XJ6 series3 engine, I have modified a set of triple SU's so they are now Throttle bodies and intend to run these with a Megasquirt
My question are there any megasquirted straight 6 engines on this forum, I have seen a few V12's I am interested in obtaining some maps fuel and ignition to create a good base map, if any of you can assist I would appreciate
Chris
Chris
Series 2 FHC, + C type replica
tim wood
#2 Re: Megasquirt 4.2 series 3 XJ6
Post by tim wood » Tue Jan 23, 2018 7:34 pm
Hello Chris - is this the Chris I know?
Tim
#3 Re: Megasquirt 4.2 series 3 XJ6
Post by mgcjag » Thu Jan 25, 2018 2:19 pm
Hi Chris....you may have seen it but have a look here viewtopic.php?f=6&t=11588&hilit=Megasquirt one of the posters Marek is very knowledgable and runs Megasquirt on his V12..send him a PM lm sure he will be very helpefull......
Tim...yes its the same Chris....all the best.... Steve
#4 Re: Megasquirt 4.2 series 3 XJ6
Post by MarekH » Thu Jan 25, 2018 3:59 pm
I seem to recall that a chap called Pete Congreve has squirted a 6cylinder etype, so you steal a map from him if you can find him. There is no need though, since you can start with an ignition map from anyone who has converted to EDIS, which is covered in another thread somewhere. You can then sort out your fuelling map using the Tunerstudio's autotune feature.
Purchase the newest version of TS and MLVhd. The graphing and tabling features of the hd version of MLV are well worth it.
tim wood
#5 Re: Megasquirt 4.2 series 3 XJ6
Post by tim wood » Thu Jan 25, 2018 5:12 pm
Hi Chris,
I think most posters on here would take good note of the comments from Marek.
Could you let me have the details of that guy in Northampton who refurbed your calipers. I’ve dropped the rear cage and given the hassle it is I’m going to have these brakes done and tested professionally. On looking at the cage I don’t think it’s ever been out before. All the original mounts and shims in place. The bolts were bloody tight. I’m going to put new UJs on the prop before I refit.
Speak soon
Tim
ChrisCtype
#6 Re: Megasquirt 4.2 series 3 XJ6
Post by ChrisCtype » Thu Jan 25, 2018 8:59 pm
Tim
yes its me, I will send you the Brake guys details
I think ive seen some of your posting on V12, but will look again at the link as I will be running wasted spark using Edis 6
James is sending me his emerald map which I can look to tanspose into MS, I have a tuner studio licence but I will look into the later version and see if I can upgrade, I have used the TS on my previous Westfield but its been a while since I've used it
cheers
Chris
Chris
#7 Re: Megasquirt 4.2 series 3 XJ6
Post by mgcjag » Sat Jan 27, 2018 10:37 am
