Securing seals in place
Spark
#1 Securing seals in place
Post by Spark » Thu Jan 25, 2018 7:05 am
Series1 2+2
Any advice on securing the seals in place on the car
Boot seal, door seals ets
Should I use contact adhesive which is very messy or an alternative
Also what should I use under front and rear screens to ensure water tight, if anything??
Any guidance please greatfully received
Thank
#2 Re: Securing seals in place
Post by christopher storey » Thu Jan 25, 2018 11:46 am
I'm afraid there is no alternative to contact adhesive . Hutson's will sell you a tin of the stuff they use, and the trick that they advise is to brush a thin layer onto the metal and leave that to go off for 24 hours before you start . This acts as a primer for the coat which actually does the sticking
As far as screen sealants are concerned, Arbomast Autograde is the stuff - it is a non hardening sealant ( but it skins over as it cures ) which prevents the ingress of water but does not transmit shocks to the glass and is sufficiently flexible to accommodate temperature changes etc - available from Dortech . You will probably need 2 tubes for your job. It is best used from the very start i.e. before the screens and any seals are put in , you coat the metal flanges with it , and then put it in the rebate in the screen rubber before the glass is put in
#3 Re: Securing seals in place
Post by mgcjag » Thu Jan 25, 2018 11:53 am
Hi Spark.....whats your name....please try to put it and your car model in the signature area.......none of the seal that i have replaced have ever had any sealer on them.....and i havent used any when replaceing them....apart from the seal on the door cill and the bumpers which have to be glued in place ....never replaced a front screen but have done a rear....no sealer used.....Steve
#4 Re: Securing seals in place
Post by abowie » Thu Jan 25, 2018 10:12 pm
Terrible stuff. Messy and hard to work with.
I use cyanoacrylate (Super Glue).
Spark
#5 Re: Securing seals in place
Post by Spark » Sat Jan 27, 2018 3:25 pm
Thanks for the feedback guys
Will Speak to Andy
Any other alternatives being used
#6 Re: Securing seals in place
Post by mgcjag » Sat Jan 27, 2018 4:10 pm
Hi Phil...just search on Adhesive...there is 14 pages of various info for trim/seals etc.... search.php?keywords=Adhesive Steve
