The rear cage on my car is caked with grease and muck an unbelievable amount of greasy crud.
It’s now dropped out and in bits on the garage floor.
Thought I would try the degreaser from screwfix as I had read good reports. Picked up 5 litre for under a tenner and dropped some bits in a 50/50 mix of water and this stuff. Amazing, cleans off all of the muck and much safer than using spirit based products.
I used some neat on some parts and again good results.
Worthwhile trying if like me you are up to your elbows in the mucky stuff. Cheap too !
Tim
Screwfix degreaser
#1 Screwfix degreaser
#2 Re: Screwfix degreaser
I'll second that. I used it to clean up my bargain used four post lift before painting it.
Neil
1962 S1 OTS
1967 S1 FHC
1962 S1 OTS
1967 S1 FHC
#3 Re: Screwfix degreaser
Another vote for it
#4 Re: Screwfix degreaser
Yes, it works great.
I also use the Clarke parts washer detergent with good results.
