[solved] S1 heater box: secret locking?
paydase
#1 [solved] S1 heater box: secret locking?
Post by paydase » Sun Feb 04, 2018 9:20 pm
Hi all,
Preparing to refurb my heater box, I have tried unsuccessfully to remove the front plate of the box after having removed the 6 holding screws (including the one below) even by prying off the plate.
The external part of the bottom center axle that allows moving the interior air flap seems to be solidly bound to the plate.
It seems to me that the axle should slide freely through the plate unless rust has bound the axle, a washer and the plate together.
Could you confirm that I should insist in prying off the plate to remove it?
Thanks for your help
heater box axle.jpg (253.02 KiB) Viewed 8285 times
Serge
1964 (3.8) FHC
1961 OTS
#2 Re: S1 heater box: secret locking?
Post by abowie » Mon Feb 05, 2018 2:29 am
They're frequently very difficult to get that shaft out of.
#3 Re: S1 heater box: secret locking?
Post by 1954Etype » Mon Feb 05, 2018 7:57 am
As Andrew says, they can be really tight. Be careful prying it off as you will bend the end cover. Soak it in penetrating oil and slowly work the flap up and down. If it is really stuck, carefully apply some heat with a hot air gun.
When you have it back together, it is a good idea to lubricate this shaft every so often as it will bind up again.
Simon P
#4 Re: S1 heater box: secret locking?
Post by Simon P » Mon Feb 05, 2018 8:58 am
Sounds like advice from Swiss Toni! "You know, restoring an E-type is very much like making love to a beautiful woman...." :bigrin: :bigrin:
1969 S2 FHC - 1R20258
2008 Caterham Seven Roadsport
Jeremy
#5 Re: S1 heater box: secret locking?
Post by Jeremy » Mon Feb 05, 2018 9:51 am
And you might try Plus Gas, which I've found to be the most effective penetrating oil - better than WD40.
In my case that sticking shaft was the least of the problems... The inside of the box was in a terrible state and I ended up scrapping it. Hope yours is OK...
Jeremy
1967 S1 4.2 FHC
paydase
#6 Re: S1 heater box: secret locking?
Post by paydase » Mon Feb 05, 2018 2:58 pm
Thanks everybody.
I was really starting to doubt...
I will go back and charm the snake!
Serge
1964 (3.8) FHC
1961 OTS
paydase
#7 Re: S1 heater box: secret locking?
Post by paydase » Mon Feb 12, 2018 6:44 pm
It was a real pig but finally I unlocked the Ali Baba door!
The advice to first heat it with an hot air gun allowed to move the shaft by hammering it.
Thank you for the tip, now dismantled.
I will start to restore the radiator first, hoping that it can be put back to life.
Seems to me that it has in/out copper tubes and copper fins but that the two blocks on each side and the frame holding the fins are made of aluminum.
Would the right way to treat it be immersing the whole radiator in a diluted phosphoric bath for some time or/and to flow the phosphoric acid in the pipes?
heater box dismantled.jpg (255.31 KiB) Viewed 8096 times
Serge
1964 (3.8) FHC
1961 OTS
ralphr1780
#8 Re: [solved] S1 heater box: secret locking?
Post by ralphr1780 » Mon Feb 12, 2018 9:16 pm
Good progress Serge.
As for the radiator, personally I would not hesitate and straightly install a new one first tested on the bench.
I would hate restoring then installing, and facing a leak some time later.
Ralph
'69 OTS + '62 OTS - Belgium
MarkRado
Austria
#9 Re: [solved] S1 heater box: secret locking?
Post by MarkRado » Tue Feb 13, 2018 5:05 am
Serge,
depending on how you are going to use your car, this would be be the opportunity to upgrade the unit. Using mine frequently in autumn and sometimes even in winter, I can tell that heater core and fan definitely leave a lot to be desired. There are a few threads on the forum about improvement; I ve already got the Fiero fan, it only needs to be installed :shock: Ah, and of course you need an upgraded Matrix.
1963 OTS 880436
#10 Re: [solved] S1 heater box: secret locking?
Post by Series1 Stu » Tue Feb 13, 2018 9:33 pm
I too have the Fiero fan and motor ready to go in but am still undecided about the matrix. Are there any upgraded heaters other than the Clayton Classics item?
mark10337
Switzerland
#11 Re: [solved] S1 heater box: secret locking?
Post by mark10337 » Tue Feb 13, 2018 10:25 pm
Yes. I'm very pleased with the upgraded unit from M&C Wilkinson. Keeps me warm on winter drives.
-Mark
#12 Re: [solved] S1 heater box: secret locking?
Post by rswaffie » Sun Feb 25, 2018 4:31 pm
Hi Mark
Regarding the M&C heater motor, I’m just rebuilding the heating system and mine came with a large resistor unit, that it looks like clamps to the motor body. There were no diags or instructions so I’m not sure of the correct position for this. Did you use this, or the original resistor?
I’m guessing it would sit below the 3 brackets, over the Clayton sticker?
mark10337
Switzerland
#13 Re: [solved] S1 heater box: secret locking?
Post by mark10337 » Sun Feb 25, 2018 4:47 pm
I only replaced the heater core and not the motor as well. I would recommend using the full package they supplied to you as that resistor will be matched and checked with that motor's specification. The resistor is usually mounted so it is on the bulkhead side
-Mark
#14 Re: [solved] S1 heater box: secret locking?
Post by rswaffie » Sun Feb 25, 2018 9:46 pm
Cheers Mark.
mark10337
Switzerland
#15 Re: [solved] S1 heater box: secret locking?
Post by mark10337 » Mon Feb 26, 2018 4:39 am
looking at the picture again you can just see 1 of the 2 holes on the base plate where the resistor should be riveted to.
-Mark
