Hello again all. Having somewhat moved on in the A/C switch department, I have offered up the evaporator unit under the dash. Thing is that I can’t see how the unit is secured , other than the thin metal plaques on the frontside of the unit itself.
Any info/photos would be greatly appreciated
A/C underdash evaporator unit mounting
#2 Re: A/C underdash evaporator unit mounting
I am trying to find a picture , but there is a simple right angle bracket way over on the right ( pass) side by the edge of the fan housing that screws to the evap, and then the side panel. it is nothing fancy and basically a 90 degree cabinet bracket thats about an inch long. that and the radio housing help support the whole contraption along with the brackets you mention.
Bob F
Bob F
Bob F
69 S2 E-type OTS LHD
#3 Re: A/C underdash evaporator unit mounting
i can't seem to find my old AirCon manual but as I recall, there are two tabs holding the unit tight to the underdash, while also two screw attachments at the sides. You remove the screws and pull the evap unit toward you to remove. Hope this helps
Robert Bayers
#4 Re: A/C underdash evaporator unit mounting
Thanks indeed Bob and Robert. Sorry about the delay in responding.
Craig Balzer
#5 Re: A/C underdash evaporator unit mounting
I am in the midst of a total restoration of my Series III and have a ton of photos.
I attached a few here that may be helpful.
Any others (evaporator on my bench, underside of dash, A/C lines, etc) as requested
Craig Balzer
Colorado Springs, CO, USA
