Prop shaft universal joints
Robbiee
#1 Prop shaft universal joints
Post by Robbiee » Mon Apr 02, 2018 9:23 pm
Hi all
Any recommendations for which UJs to fit to my propshaft?
My chassis number is 850456 which SNG B website tells me is no longer available
My questions are 1. do I use the “early” ujs OR later ones?
2. Are they interchangeable ?
3. Does it matter which I choose?
Robbie
#2 Re: Prop shaft universal joints
Post by chrisfell » Tue Apr 03, 2018 6:40 am
You may be offered “sealed for life” UJs. Whilst these are true to their descrption it is only because their life will be very short These may be fitted with a grub screw in the central spider. Remove it and throw it away and fit a grease nipple. If there is no grub screw, find an alternative that has a grease nipple. Then remember to grease the UJs once every year.
#3 Re: Prop shaft universal joints
Post by mgcjag » Tue Apr 03, 2018 7:22 am
Hi Robbie..sorry dont know the answer but if you can get a number from your existing ones or measure them then you could go directly to a prop/bearing company.....you can also try Norman Morors....very good at haveing old stock Jag parts.......Steve
