Cold starting problem
dereksharpuk
#1 Cold starting problem
Post by dereksharpuk » Sat May 26, 2018 3:44 pm
My Series 2, running on triple SUs has just had a total engine rebuild, fitting of 123 electronic ignition and a good rolling road tune. It starts beautifully second time of the day (hot or cold), but first time it coughs, and stops about 5 times after turning the key, no matter where the throttle is. I can hear the fuel pump working when the ignition is first turned on. Do you think this is fuel trying to get to the carbs? It drive beautifully and as I said, once started, it when I turn it of & start again it starts instantly and idles smoothly at about 800 RPM. The battery is fine.
Derek Sharp
Series 2 4.2 OTS
#2 Re: Cold starting problem
Post by chrisfell » Sat May 26, 2018 3:55 pm
These symptoms can be caused by insufficient enrichment.
In other words the choke isn’t dropping the main jets.
#3 Re: Cold starting problem
Post by mgcjag » Sat May 26, 2018 4:15 pm
Hi Derek....for first start when cold pull out the choke...dont touch the throttle.........does it start and run....slowly pushing in the choke.....Steve
dereksharpuk
#4 Re: Cold starting problem
Post by dereksharpuk » Sat May 26, 2018 4:59 pm
Thanks both. I'll check that the choke is working properly.
Derek Sharp
Series 2 4.2 OTS
