brake master cylinder push rod adjustable or not ?
Polse7317
#1 brake master cylinder push rod adjustable or not ?
Post by Polse7317 » Mon Jun 25, 2018 4:13 pm
I am refurbishing the brakes on my serie 1 and i see on the manual an adjustable brake master cylinder push rod on the top master cylinder for the rear brakes and a NON adjustable one for the lower one for the front brakes.
Is it correct ? i have actualy two non adjustable one ..... and my brakes are blocked after 2 or 3 foot press on the pedal and i can't adjust them !!!
:scratchheadyellow: thank's for the advices
#2 Re: brake master cylinder push rod adjustable or not ?
Post by abowie » Mon Jun 25, 2018 9:22 pm
Yes. One rod needs to be adjustable to allow for correct setting of freeplay.
Polse7317
#3 Re: brake master cylinder push rod adjustable or not ?
Post by Polse7317 » Tue Jun 26, 2018 6:59 am
Must it be the upper one ( as i think reading the manual ) or any one ?
#4 Re: brake master cylinder push rod adjustable or not ?
Post by abowie » Tue Jun 26, 2018 8:02 am
Mine is the upper one.
Polse7317
#5 Re: brake master cylinder push rod adjustable or not ?
Post by Polse7317 » Tue Jun 26, 2018 12:00 pm
Thank's Andrew
#6 Re: brake master cylinder push rod adjustable or not ?
Post by cactusman » Tue Jun 26, 2018 2:58 pm
Workshop manual shows upper cylinder fitted with an adjustable fork and this feeds the rear brakes....my car is the same :bigrin:
