Window frame ‘T’ seals - orientation?
#1 Window frame ‘T’ seals - orientation?
Post by rswaffie » Sun Aug 05, 2018 5:23 pm
Hi All,
I have the ‘T’ seals the fit along the top and forward face of the windo frame. The seal flange is off-set from centre so it looks like it should be fitted one way only!
Which way should it go? When closed, should it seal against the body at X or Y below?
paulsco
#2 Re: Window frame ‘T’ seals - orientation?
Post by paulsco » Mon Aug 06, 2018 12:23 pm
Hi Richard,
The seal sits with the curve facing outwards, away from the car; 'Y' is to the outside.
#3 Re: Window frame ‘T’ seals - orientation?
Post by rswaffie » Mon Aug 06, 2018 12:25 pm
Great, thanks Paul.
