Hard starting whe cold
Jetjock17
#1 Hard starting whe cold
Post by Jetjock17 » Fri Sep 21, 2018 4:54 am
Once running the engine runs great and starts immediately when warm. Once cold however, it needs a lot of cranking with full choke before firing and running on one or two cylinders before finally picking up and responding to the throttle. Adjusted the choke cables but no improvement. Ideas?
tim wood
#2 Re: Hard starting whe cold
Post by tim wood » Fri Sep 21, 2018 11:46 am
Lots of previous discussions on this. Worth searching the forum.
#3 Re: Hard starting whe cold
Post by Heuer » Fri Sep 21, 2018 1:11 pm
If you look at the bottom of the page you will see the Forum automatically searches for any relevant posts and lists the top five.
