Cable protector in footwell on Series 2, but not 2+2
CTDavies
#1 Cable protector in footwell on Series 2, but not 2+2
Post by CTDavies » Sat Dec 29, 2018 8:27 pm
Hello All,
It appears that the Series 2 cars had a cable protector in the left side footwell as a conduit of some sort. By going through the parts lists it seems that the 2+2 didn‘t have it, which can only mean that harness was routed differently. Is this correct?
The part is number 37 on the image here.
1969 2+2 Series II
Home Restoration
Durango2k
#2 Re: Cable protector in footwell on Series 2, but not 2+2
Post by Durango2k » Sat Dec 29, 2018 8:40 pm
My S 1 2+2 has it. Folded „Pappkarton“.
Carsten
CTDavies
#3 Re: Cable protector in footwell on Series 2, but not 2+2
Post by CTDavies » Sat Dec 29, 2018 8:50 pm
Hi Carsten,
BAS has it in their catalogue for Series 2 OTS and Coupes, but not for the 2+2. I guess there‘s nothing wrong with installing one in a S2 2+2, to hide and protect the cables. Pappkarton (cardboard in english) sounds a bit flimsy. Could you provide dimensions? Then I could have on made from thin alumin(i)um. Thanks,
Chris, in Germany
1969 2+2 Series II
Home Restoration
Durango2k
#4 Re: Cable protector in footwell on Series 2, but not 2+2
Post by Durango2k » Sat Dec 29, 2018 9:16 pm
Hi Chris,
I think I already fitted it, and it was not easy, so I am a bit reluctant to remoove it.
Maybe someone else has a loose one?
Carsten
CTDavies
#5 Re: Cable protector in footwell on Series 2, but not 2+2
Post by CTDavies » Sun Dec 30, 2018 8:38 am
No problem, Carsten. I‘ll just order one through BAS. They seem to be the only ones who stock it these days.
But can anyone explain why it was not used for the Series 2 2+2?
Chris, in Germany
1969 2+2 Series II
Home Restoration
Durango2k
#6 Re: Cable protector in footwell on Series 2, but not 2+2
Post by Durango2k » Sun Dec 30, 2018 8:45 am
If I do not forget it I‘ll take a few pictures from it in „mounted condition“, and its the re-used original part...
Carsten
#7 Re: Cable protector in footwell on Series 2, but not 2+2
Post by mgcjag » Sun Dec 30, 2018 10:10 am
Hi Chris.....the part for the fhc is shown here on the sng web page......the same page for the 2+2 shows the part as no longer available....https://www.sngbarratt.com/uk/#!/Englis ... cb4d53f0c1
My 69 2+2 has the protector rivited to the side panel.....could it be that it was all under one part number(panel & protector)...my protector is a different shape to the one shown in the link......its more hocky stick shaped with the curved end faceing the passenger seat........Steve
CTDavies
#8 Re: Cable protector in footwell on Series 2, but not 2+2
Post by CTDavies » Mon Dec 31, 2018 3:57 pm
Hi Steve,
thanks for that information. It looks as if the 2+2 certainly also had it. I haven‘t decided yet which one I‘m going to order. Maybe an original hockey shaped one will show up on eBay, who knows?
Chris
1969 2+2 Series II
Home Restoration
paulsco
#9 Re: Cable protector in footwell on Series 2, but not 2+2
Post by paulsco » Tue Jan 01, 2019 12:46 pm
This is the orignal one on my Series One FHC:
Polse7317
#10 Re: Cable protector in footwell on Series 2, but not 2+2
Post by Polse7317 » Wed Jan 02, 2019 9:16 am
I have exactly the same in my 63FHC
before and after :
paulsco
#11 Re: Cable protector in footwell on Series 2, but not 2+2
Post by paulsco » Wed Jan 02, 2019 10:08 am
The one on mine is steel not aluminium.
Polse7317
#12 Re: Cable protector in footwell on Series 2, but not 2+2
Post by Polse7317 » Wed Jan 02, 2019 1:41 pm
You are right Paul.....it's steel
CTDavies
#13 Re: Cable protector in footwell on Series 2, but not 2+2
Post by CTDavies » Sun Jan 06, 2019 9:47 am
Thanks to everyone for helping here. I do believe the cable protector was installed on the 2+2 but is simply not included in the parts lists, for whatever reasons.
Chris Rooke also shows this in his book on pages 226 and 228, with detailed pictures, which are also very helpful.
I‘m intrigued by Casten‘s comment that his is folded cardboard (Series 1 2+2). There‘s a metal one on ebay right now for auction. I‘m going to try to get that one.
Chris, in Germany
1969 2+2 Series II
Home Restoration
#14 Re: Cable protector in footwell on Series 2, but not 2+2
Post by mgcjag » Sun Jan 06, 2019 10:00 am
Hi...my 69 S2 2+2 is also a type of cardboard..note the 2+2 is a very different shape to the fhc/ots cover..Steve
Ps here are a couple of photos of mine.....note the cutout in the dash under panel to alow the curver shape to fit
Durango2k
#15 Re: Cable protector in footwell on Series 2, but not 2+2
Post by Durango2k » Sat Jan 12, 2019 5:33 pm
Here‘s mine:
Carsten
CTDavies
#16 Re: Cable protector in footwell on Series 2, but not 2+2
Post by CTDavies » Sun Jan 13, 2019 7:57 pm
Thanks for those pictures, Carsten (Hope you didn‘t have to dismantle it again to take them). It surely matched your previous description of folded cardboard. In the mean time I‘ve found mine, which is also folded cardboard covered in black vinyl, although the interior was suede green. Mine is in really bad shape. I‘m not sure if mine can be fixed.
1969 2+2 Series II
Home Restoration
Durango2k
#17 Re: Cable protector in footwell on Series 2, but not 2+2
Post by Durango2k » Sun Jan 13, 2019 8:25 pm
I had to take it out whilst searching for the front right indicator power supply, hence the opportunity for a set of pics for you. I had to dig in this area....deep.
I think suede green leather did come with GREY vinyl, as you can see on the side protector, my car did. I think my seats were actually grey, but as the PO did paint them with a black rattle can, well, I tore the leather of and in the bin it went.
I was lucky enough to find a set of "black" seat covers from an S1. Sadly the rear side was vinyl not velours (as it should have been), but I choose to ignore that, plus they were not black but again "painted" suede green.
I re-newed the "paint" on the via the Lederzentrum.de product range, but sometimes a green shine appears. Its ok for me. And I re- did the rest of the car in black vinyl, so its all ok now. Just VERY dusty....
Carsten
tim wood
#18 Re: Cable protector in footwell on Series 2, but not 2+2
Post by tim wood » Sun Jan 20, 2019 8:47 pm
This is for sale on eBay
https://www.ebay.co.uk/itm/Jaguar-E-Typ ... SwJOJcRNrj
May be of use
