no power to fuel pump
gipson609
#1 no power to fuel pump
Post by gipson609 » Tue Jan 15, 2019 10:10 pm
1969 xke has no power at fuel pump. there is power on both sides of fuse #6. is there a connection somewhere between the fuse and the fuel pump
Bfastr
#2 Re: no power to fuel pump
Post by Bfastr » Tue Jan 15, 2019 10:19 pm
its a white wire that picks up off fuse 6, but it doesnt actually go thru the fuse. the white wire goes over to a bullet connector over by the glove box under the dash before heading back to the pump. You might look there for white wires in a rubber bullet plug. check the connections there.
Bob F
Bob F
69 S2 E-type OTS LHD
gipson609
#3 Re: no power to fuel pump
Post by gipson609 » Wed Jan 16, 2019 7:49 pm
Thanks Bob. I found the connector under the glove box and it appears to have power from the fuse area. What does this box do? Could it be bad?
Bfastr
#4 Re: no power to fuel pump
Post by Bfastr » Wed Jan 16, 2019 10:21 pm
I is just a connection from the dash wiring to the harness that runs to a few things on the right side and down along the sill to the back and pump. I cant recall off the top of my head if there are two or three whites joined there, I would pull them all out, make sure they are clean with a little scotch brite and plug them back in. From there I am pretty sure the white is uninterrupted all the way to the pump. the black thing you are looking at should just be a hard rubber connector, inside are little barrels the wires plug in to.
should be a jumble of connectors like this hanging out of the dash in the top of picture
Bob F
johnetype
#5 Re: no power to fuel pump
Post by johnetype » Thu Jan 17, 2019 12:01 am
The white wire is indeed uninterrupted all the way to the pump from this point.
1969 Series 2 FHC
Jage70
#6 Re: no power to fuel pump
Post by Jage70 » Thu Jan 31, 2019 2:58 pm
While you are investigating this "W" wire to get power to the fuel pump.....why not install an inline fuse...because this white comes off the input of power to fuse 6 and is not fused!!
