IRS Renovation
Philk
#1 IRS Renovation
Post by Philk » Sat Feb 16, 2019 9:46 am
I have just received our S1 3.8 OTS back following its IRS being renovated at Southern Classics at Twickenham. A superb job done and would fully recommend Steve and his team to fellow forum members. In terms of the work performed (as per photos below).
- IRS cage and major components bead blasted and powder coated.
- Vapour blasting of those components which have a natural finish.
- Replating where required.
- New Boge Shock Absorbers (painted BS633 with Girling stickers) and standard springs
- Differential seals replaced (no major internal work required) and painted to correct colour
- Coopercraft calipers fitted with bleed extension pipes for ease of future bleeding
- Handbrake mechanism overhauled
- New discs (edges painted to avoid corrosion) and pads
- New bushes and other wear/tear components
- New hub splines
- Reinstatement of original half-shaft shrouds and re-plated Cheney clips
1964 S1 3.8 OTS
#2 Re: IRS Renovation
Post by mgcjag » Sat Feb 16, 2019 9:51 am
Hi Phil...looks great....befor you install it have you considered the simple handbrake mod http://forum.etypeuk.com/viewtopic.php?t=6170 Steve
Philk
#3 Re: IRS Renovation
Post by Philk » Sat Feb 16, 2019 10:21 am
To be honest, I hadn't since I had not had any issues with the handbrake's effectiveness previously. The IRS is now back in the car so I'll see how it goes in the coming months.
1964 S1 3.8 OTS
#4 Re: IRS Renovation
Post by abowie » Sat Feb 16, 2019 11:04 pm
A newly restored IRS always looks very nice.
FWIW what did they charge you?
