carburettor leaking fuel
Lemans88
#1 carburettor leaking fuel
Post by Lemans88 » Mon Feb 18, 2019 4:37 pm
After 31 years of moderate use a recent outbreak of misfiring under load seems to be traceable to fuel leaking from under the f/o/s Stromberg.
Before I set about closer inspection & dismantling on a nice warm day, can anyone please advise size of, & preferably a source for, the jet cover neoprene (?) O ring so I can at least replace that if it's the culprit?
Thanks.
JJC
#2 Re: carburettor leaking fuel
Post by JJC » Mon Feb 18, 2019 4:42 pm
Best source for correct part, and sage advice, is always Joe Curto in NYC, USA. In this day and age with email, cell phones, with satellite links, and quick shipping, he is the man !! Check his web page.
JJ
#3 Re: carburettor leaking fuel
Post by Heuer » Mon Feb 18, 2019 4:50 pm
In the UK: http://zenithcarb.co.uk/?SID=s9r9m67557 ... ore=zenith
Lots of information concerning overhaul and parts along with downloads of manuals and parts lists. We also have a few documents in the Forum Knowledge Base:
Stromberg Overhaul Guide (74 pages!): https://www.dropbox.com/s/clmwrlgonv8gx ... 2.pdf?dl=1
Stromberg manual (Leyland): https://www.dropbox.com/s/kd8urr3l411dh ... d.pdf?dl=1
Stromberg Needle guide: https://www.dropbox.com/s/domenkpzexkqw ... e.xls?dl=1
Stromberg Strip down by David Lacey: https://www.dropbox.com/s/48pmsd9osrrwi ... n.pdf?dl=1
Pictorial Stromberg strip down guide: http://www.howacarworks.com/fuel-system ... arburettor
rossco_j
#4 Re: carburettor leaking fuel
Post by rossco_j » Mon Feb 18, 2019 11:11 pm
Thanks for the links David. Very useful...
Ross
1972 Series 3 E Type 2+2
1972 MGB GT
1965 Mini Cooper
1954 Austin A30
https://rossjohnsonphotography.zenfolio.com/
Ole-xke1974
#5 Re: carburettor leaking fuel
Post by Ole-xke1974 » Tue Feb 19, 2019 12:34 pm
I had similar fuel leaks from under my Strombergs.
That was after a refurbishment that off course included new needle valves. Guess what, one of the new valves started leaking after just a couple of years. No trace of crud in it, so I replaced it with an old one that has worked since.
An other time it was the plugs with the O-ring. Not the O-ring, but the plug was weak and brittle and could not stay tight and snug. SNG supplied the plugs in two days.
Cheers ...... Ole
71 V12
#6 Re: carburettor leaking fuel
Post by 71 V12 » Tue Feb 19, 2019 11:12 pm
I researched the dimension of the o ring a while ago and came up with this:
https://www.ebay.co.uk/itm/Imperial-O-R ... 1438.l2649
I have not fitted them yet but cheap and easy to fit, maybe worth a try.
vee12eman
Kiribati
#7 Re: carburettor leaking fuel
Post by vee12eman » Tue Feb 19, 2019 11:32 pm
One of the issues with the o ring seal under the carb is corrosion of the float chamber body. If this has occurred then new o rings may prove to be a short term fix. Once disturbed and cleaned (because you will clean it before refitting), the pitting from the corrosion may actually be worse than before, since the corrosion itself is gone, leaving only the pits. A new o ring may or may not cope with this for an indeterminate length of time.
I overcome this with a very thin smear of a FUEL RESISTANT sealant, making very sure none ends up inside the chamber bowl. My method is to apply to the the lowest inside portion of the bore so that as the bowl is refitted, the new seal tends to push the sealant down and out of the bore. I then apply a little more sealant around the plug, again, sparingly. I now do this routinely, even if I can’t see corrosion in the chamber bowl bore. As already suggested, I also replace the plastic plug completely (if applicable) as they tend to become weak and or brittle over time and frequently fail to retain correctly. You can change the chamber for a new one too, but it starts getting expensive and I can’t afford that!
Simon.
Series III FHC
Ole-xke1974
#8 Re: carburettor leaking fuel
Post by Ole-xke1974 » Wed Feb 20, 2019 12:36 pm
Simon.
Good tip, thanks Simon
