Silencers
Bernie2015
#21 Re: Silencers
Post by Bernie2015 » Tue Mar 12, 2019 8:57 am
Thanks Steve it does but what would realy help is knowing what the distance between centres on inlet and outlet pipes on the car should be and then I would know if the car had been modded or the pipe stubs on the new silencers are incorrect.
Bernie 1966 S1 OTS
Bernie2015
#22 Re: Silencers
Post by Bernie2015 » Tue Mar 12, 2019 8:59 am
Thanks Steve it does but what would realy help is knowing what the distance between centres on inlet and outlet pipes on the car should be and then I would know if the car had been modded or the pipe stubs on the new silencers are incorrectly placed.
Bernie 1966 S1 OTS
#23 Re: Silencers
Post by mgcjag » Tue Mar 12, 2019 9:02 am
Hi Bernie.....the width between the front pipes can be altered..the rear is more or less determined by the width of the i/p of the rear box......not going to be easy to find someone with an original system still installed.....Steve
Bernie2015
#24 Re: Silencers
Post by Bernie2015 » Tue Mar 12, 2019 9:09 am
That's very interesting thanks Steve - it didn't occur to me to try and change the centres of the front pipes is it straightforward?
Bernie 1966 S1 OTS
#25 Re: Silencers
Post by mgcjag » Tue Mar 12, 2019 9:14 am
Hi Bernie.....there is no real adjustment but with exhausts in general it can be easier to fit parts by loosing everything else off starting at the connection to the manifold....so that everything can move.....then fit the new parts....get in best position and tighten.....it might work for you unless you have a serious mismatch/manufacturer error......all the best...Steve
Bernie2015
#26 Re: Silencers
Post by Bernie2015 » Tue Mar 12, 2019 9:16 am
Thanks Steve will give it a try
Bernie 1966 S1 OTS
#27 Re: Silencers
Post by mgcjag » Mon Apr 15, 2019 8:06 am
Hi Bernie...did you get this problem resolved.....I know that SNGB are currently looking at a similar fitment problem..Steve
Bernie2015
#28 Re: Silencers
Post by Bernie2015 » Wed Apr 17, 2019 8:10 am
My mechanic had to fit an adaptor so the ends would meet up with existing exhaust
Bernie 1966 S1 OTS
