Diff Breather Tube 'Missing'
Ian Cooke
#1 Diff Breather Tube 'Missing'
Post by Ian Cooke » Sun Mar 17, 2019 5:17 pm
Hi All
Whilst under the car removing the drain plug to change the diff oil, I noticed that the breather tube is missing. The elbow is there but no tube.
This gives rise to a number of questions:
1) Any ideas why the tube is missing?
2) Is it a case of ordering a new tube and 'just' screwing it in?
3) Should I remove the elbow and / or the diff cover to clean the elbow and make sure its not blocked?
4) If the answer to 3 is 'yes', can this be done with the IRS in situ as I'm not confident enough to remove it?
Any advice is much appreciated.
Ian
Ian Cooke
1969 S2 FHC in Old English White
#2 Re: Diff Breather Tube 'Missing'
Post by mgcjag » Sun Mar 17, 2019 5:39 pm
Hi Ian....no idea why its missing..was it ever there....came loose and fell off...just unscrew elbow and check its clear.....screw back in..possiby with s bit of thread sealer.....order new pipe and screw into elbow....easy...Steve
Ian Cooke
#3 Re: Diff Breather Tube 'Missing'
Post by Ian Cooke » Sun Mar 17, 2019 6:14 pm
Thanks Steve, sounds straightforward.
Is there a trick to unscrewing the elbow? It's quite difficult to get to unless I'm missing something obvious!
Ian Cooke
#4 Re: Diff Breather Tube 'Missing'
Post by mgcjag » Sun Mar 17, 2019 6:29 pm
No tricks just anticlockwise.....yes not easy to get to.far easier if irs is out but thats a bit overkill.....car up on a lift helps........Steve
Ian Cooke
#5 Re: Diff Breather Tube 'Missing'
Post by Ian Cooke » Mon Mar 18, 2019 5:59 pm
Thanks again Steve
I managed to get the elbow out without too much difficulty and I'm now just waiting for the replacement tube to arrive.
It looks like the original tube snapped off as the thread from the tube is still in the elbow!
Ian
Ian Cooke
#6 Re: Diff Breather Tube 'Missing'
Post by mgcjag » Mon Mar 18, 2019 6:04 pm
Well done...to refit you have to fit elbow first then the tube....Steve
