Maybe it is a silly question, but - does the lower L part of the torsion bar shields face outwards ?
Seen from the drivers seat, it would be that : _I Engine sump here I_ ?
This would mean the torsion bars are in fact free - and the frame is shielded of from the torsion bars (or did the think stones come from the wheels but not from below ? Why not I_ _ I ?
If you look at the one long original TBS above, it must be the RH part. Look at the grime, you can see the imprint of the cloth. And this presses against the lower frame, and the cutout must be at the front. So this is the RH part. The L is then facing outwards.
I am missing the LH rear part. And the LH under battery part.
The one with the round 2 inch cutout goes in front of the air intake trumpets according to the Chris Vine resto page.
Would you fit a long LH part (I have fitted standard downpipes, not the 2+2 siamesed system) ?
And finally, I would love to be able to identify this item :
Maybe it is the lower „radiator protection shield“ ?
Carsten
