Gauges show wrong readings sometimes
rojakilian
#1 Gauges show wrong readings sometimes
Post by rojakilian » Sun May 19, 2019 8:08 pm
Hello Jaguar Gearheads,
i got a 64 3.8 coupe. During the last drives the indications of fuel, water temperature and oil pressure gauges go down and then up again to normal readings simultaniously.
What could be wrong?
Thanks for your help.
Best regards
Robert
:wavegreatbritain:
#2 Re: Gauges show wrong readings sometimes
Post by cactusman » Sun May 19, 2019 8:52 pm
They are all fed from the same fuse so maybe it is loose?
MSM
#3 Re: Gauges show wrong readings sometimes
Post by MSM » Mon May 20, 2019 1:32 pm
Much more likely to be the instrument voltage regulator mounted behind the rev counter. Solid state ones are now available to replace the mechanical version.
Mike
1969 S2 FHC
