Accelerator Stop plateGetting ready to install
Collfryn
#1 Accelerator Stop plateGetting ready to install
Post by Collfryn » Thu Aug 29, 2019 6:57 pm
Getting ready to begin reassembly of my Series 1 2+2. Checking the accelerator controls I realise I'm missing the accelerator stop plate C20639. Not sure of the function of this piece or if it goes above or below the bulkhead. I'd prefer to make one rather than pay £28 for a replacement. Could someone please tell me how thick the plate is and whether its made from steel or aluminium. Thanks
Richard Marsh
1967 Series 1 UK RHD 2+2
#2 Re: Accelerator Stop plateGetting ready to install
Post by abowie » Thu Aug 29, 2019 10:56 pm
It fits under the nuts in the footwell. The elongated holes let you slide it back and forward so you can set the rest position of the accelerator pedal.
I agree that they are very expensive and I usually bodge up a straight plate with just 2 holes out of aluminium and fit that. It's not like you can see it.
The other option is to drill and tap a hole in the back of the cast housing and fit a bolt, in the same way that your pedal box for brake and clutch may be drilled. That bolt is used to set the clutch pedal height, and you can do exactly the same thing with the accelerator.
grimes6
#3 Re: Accelerator Stop plateGetting ready to install
Post by grimes6 » Thu Aug 29, 2019 11:13 pm
Martin Robey sells them for 16 pounds .
Collfryn
#4 Re: Accelerator Stop plateGetting ready to install
Post by Collfryn » Sat Aug 31, 2019 3:04 pm
Thanks guys. I'll try some 2mm plate as soon as the body is back from paint.
Richard Marsh
