Series 1 4.2 brake servo
etypesteve
#1 Series 1 4.2 brake servo
Post by etypesteve » Mon Sep 02, 2019 12:04 pm
Will replacing a series 1 4.2 brake servo with a series 3 servo significantly improve baking efficiency- stopping distance.
I have sng barrrat 4 pot calipers on the front and standard calipers at the rear.
#2 Re: Series 1 4.2 brake servo
Post by Series1 Stu » Mon Sep 02, 2019 3:42 pm
No. It will make no difference to braking efficiency at all. It won't do anything but change the amount of braking effort at the pedal, if that.
#3 Re: Series 1 4.2 brake servo
Post by Series1 Stu » Mon Sep 02, 2019 3:47 pm
I wouldn't expect you to have a problem if you have 4 pot calipers fitted. Maybe you need larger diameter master and slave cylinders if you are running out of pedal travel.
The rear brakes play a relatively small role in stopping so the standard set up should be alright although balance might be better with series 2 rear brakes.
etypesteve
#4 Re: Series 1 4.2 brake servo
Post by etypesteve » Tue Sep 03, 2019 9:47 am
Thanks Stuart.
I really would like to have less brake pedal effort. Going from a modern car to the jag is a big difference in brake pedal force. I always keep well back from the car in front!
