I am looking for discussion threads on replacing the US only side / indicator lights with smaller, more discrete
units. I searched the forum but could not find any threads on this topic. I was wondering if anyone is aware of any solutions out there (other than welding up the holes to return to Euro spec which is a costly solution if it's to be done well.) Any advice, thoughts ? Thanks.
US only side indicators/flashers
#2 Re: US only side indicators/flashers
To some degree, how well you succeed may depend on what colour your car is, as some contrasting combinations stick out more than others.
Three suggestions:-
1/ Get some sticky tape, spray it body colour and stick it over the gap. If you have a dark colour, it may then become invisible;
2/ use xj12 side repeaters - they are a slimmer profile than the etype ones of the same Lucas part number.
3/ I make these side repeaters and can do you a set in any colour you like, e.g. in clear or smoked plastic.
Three suggestions:-
#3 Re: US only side indicators/flashers
Hi Marek,
Thanks for your swift reply, much appreciated. Do you have any photos of the clear indicators that you make, or a website link you can steer me towards? Are they the same size as the original lenses or are the smaller / slimmer in size? Thanks.
#4 Re: US only side indicators/flashers
They are exactly the same as the originals
Ole-xke1974
#5 Re: US only side indicators/flashers
As a part of my restoration which included a bare metal change of color, I deleted the US side marker lights and got the grey lenses from Marek.
I then built in the sidemarker lights in both front (amber) and tail lights (red) using flat colored LEDs.
- Attachments
- IMG_9323_reduced.jpg (99.1 KiB) Viewed 3831 times
