Braking strange things
vipergts
#1 Braking strange things
Post by vipergts » Sun Dec 29, 2019 11:59 am
On the first pump the brakes are not great however if I lift and reapply the braking efficiency is so much more powerful
Any thought?
S1 4.2 Roadster in Resale Red
#2 Re: Braking strange things
Post by cactusman » Sun Dec 29, 2019 12:04 pm
Air in the system possibly....bleed them and see if it improves. If it has suddenly happened then do carry out a thorough examination for a fluid leak - has either brake reservoir level suddenly - as a very small leak may produce a similar symptom..small leaks become big leaks and that's bad
vipergts
#3 Re: Braking strange things
Post by vipergts » Sun Dec 29, 2019 1:23 pm
It has always been this way. It does seem to use a bit of fluid, has done for years but I cannot find a leak. I guess there must be but it’s dry everywhere
#4 Re: Braking strange things
Post by mgcjag » Sun Dec 29, 2019 1:38 pm
If your loseing fluid then you have a leak...possibly into the servo or into the vac tank.....i would look in vac tank first....Steve
vipergts
#5 Re: Braking strange things
Post by vipergts » Sun Dec 29, 2019 3:06 pm
Yes. Good call.
How would it get into the vac tank?
#6 Re: Braking strange things
Post by mgcjag » Sun Dec 29, 2019 3:53 pm
Possibly via the master cylinder and reaction valve....its not uncommon for this to happen...the service manual has detailed schematic diagrams of the braking system....Steve
