Correct in a 3.8?
Herblay
Spain
#1 Correct in a 3.8?
Post by Herblay » Wed Jan 22, 2020 1:34 pm
Are these two pieces standard equipment on a 3.8 October 1962? Picture is from Jonathan Wood "Jaguar E type - The Complete History", and referred to the 3.8, but I haven't found them but in the 4.2.
S1 FHC 3.8
#2 Re: Correct in a 3.8?
Post by Gfhug » Wed Jan 22, 2020 2:06 pm
Clausager Factory Original E Type book page 21:
Change No. RA 7324 June 1964 Lifting brackets added to cylinder head, some head studs lengthened...
Does that help? A very good book to get if you're trying to be as original as possible (with Haddocks (?) books as well)
Herblay
Spain
#3 Re: Correct in a 3.8?
Post by Herblay » Wed Jan 22, 2020 3:14 pm
It helps indeed, thanks a lot. I have the Clausager but I did not see that reference, thank you for your help
S1 FHC 3.8
#4 Re: Correct in a 3.8?
Post by mgcjag » Wed Jan 22, 2020 3:19 pm
You could use the factory fit 3.8 section of the forum...lots of info there.....Steve
Philk
#5 Re: Correct in a 3.8?
Post by Philk » Wed Jan 22, 2020 4:49 pm
…. This, in turn, came from the Jaguar Spares Bulletin No. A.146 (Engine) published in August 1964. Copies of these are in the Knowledgebase section of the Forum. This confirms that it is from Engine Number RA.7324
The Service and Spares Bulletins are an excellent source of information as to when changes occurred on the cars. Most of the books on the market are quoting from these when they refer to when changes were made.
1964 S1 3.8 OTS
Tony
#6 Re: Correct in a 3.8?
Post by Tony » Thu Jan 23, 2020 12:11 am
My April 62 e type has them if that helps
Tony (E typed)
Tony
#7 Re: Correct in a 3.8?
Post by mgcjag » Thu Jan 23, 2020 8:44 am
Hi Tony....fitted at the factory....or later....Steve
Robbiee
#8 Re: Correct in a 3.8?
Post by Robbiee » Thu Jan 23, 2020 10:39 am
It was my understanding that the longer studs and engine lifting brackets were fitted from June ‘64
My March ‘62 OTS has them, yet engine block is original but the head may have been changed ..probably added later
Robbie
