jaguar etype 4.2 gearbox issue
jeffbezz
Malta
#1 jaguar etype 4.2 gearbox issue
Post by jeffbezz » Mon Feb 10, 2020 7:18 pm
hello
please help, after driving for around max 7 miles 1st / 2nd gears hard to put in, the reverse dont go in , I have to stop engine put in reverse and start engine . any ideas please.
#2 Re: jaguar etype 4.2 gearbox issue
Post by mgcjag » Mon Feb 10, 2020 8:34 pm
Hi...probably clutch adjustment....refer to the service manual and adjust the clutch slave cylinder pushrod...Steve
nefematic
#3 Re: jaguar etype 4.2 gearbox issue
Post by nefematic » Mon Feb 10, 2020 9:54 pm
Hi Jeff and welcome to the forum!
Tell us more about your car, is this a new problem whilst driving regularly, or after having work done on the car? I second Steve‘s assessment and would first check clutch hydraulics and setting of the slave cylinder.
Martin
Martin Scherz
Late S2 1970 OTS US LHD
#4 Re: jaguar etype 4.2 gearbox issue
Post by chrisfell » Mon Feb 10, 2020 10:29 pm
Many reasons, worn out release bearing is one of them.
jeffbezz
Malta
#5 Re: jaguar etype 4.2 gearbox issue
Post by jeffbezz » Sun Mar 01, 2020 9:53 am
Martin
so l have been told it's a gearbox issue, does this mean I will also have to take out the engine?
#6 Re: jaguar etype 4.2 gearbox issue
Post by mgcjag » Sun Mar 01, 2020 10:00 am
Hi ..I see you have another post on the clutch pedal issue....first thing to do is inspect inside the bellhousing...use a boroscope..small camera to look inside to check whats happening with the clutch....Engine will need to be removed to replace clutch or remove tbe gearbox...Steve
