3.8 seat frame colour
ollieoscarsid
Topic author - Posts: 81
#1 3.8 seat frame colour
Can anyone help with a colour for the seat frames on a 3.8? I can’t find anything in the knowledge base. Mine were a kind of dove grey. Thanks. Chris.
1963 S1 opalescent silver blue
#2 Re: 3.8 seat frame colour
Primer colour. Doesn't matter; you can't see them.
#3 Re: 3.8 seat frame colour
Chris,
Yep, BS381C-694 Dove Grey is the colour I used - perfect match. Incidentally I believe the factory only painted the lower area which is visible under the seat cushion & underside of the seat if removed. The “vertical” backrest behind the moquette etc. was left raw steel .... well, that’s what I found when I removed the trim on mine. I suspect this is factory correct as I also found the body number in crayon on the backside of the leather panels. Of course, I chose to paint the whole shell prior to re-trimming.
62 3.8 DHC
#4 Re: 3.8 seat frame colour
Is this Dove Grey the same colour as the soft top frames can anyone confirm?
#5 Re: 3.8 seat frame colour
Yes, a British Standard colour.
#6 Re: 3.8 seat frame colour
thanks David. I thought they looked the same colour.
ollieoscarsid
#7 Re: 3.8 seat frame colour
Thank you gents, colour looks super. To the paint shop in the morning.
#8 Re: 3.8 seat frame colour
Noli, could you post some photos you have taken during dismantling? Originality is always interesting, even if one does not always follow this path.noli383 wrote: ↑Sat Feb 15, 2020 9:00 amIncidentally I believe the factory only painted the lower area which is visible under the seat cushion & underside of the seat if removed. The “vertical” backrest behind the moquette etc. was left raw steel .... well, that’s what I found when I removed the trim on mine. I suspect this is factory correct as I also found the body number in crayon on the backside of the leather panels. Of course, I chose to paint the whole shell prior to re-trimming.
1963 OTS 880436
1963 OTS 880436
#9 Re: 3.8 seat frame colour
#10 Re: 3.8 seat frame colour
Thank you Richard, perfect documentation!
1963 OTS 880436
1963 OTS 880436
#11 Re: 3.8 seat frame colour
No problem. There’s quite a few more if you need them - I photographed the entire strip down as I went along.
#12 Re: 3.8 seat frame colour
Yes please! Thank you
1963 OTS 880436
1963 OTS 880436
