Correct distributor position?
ysmalkie
Poland
#1 Correct distributor position?
Post by ysmalkie » Sat Mar 07, 2020 7:30 pm
I am finishing my engine assembly and am trying to position the distributor.
In order to position the cables according to the manual:
I would have to place the distributor with the vacuum unit almost touching the water pipe:
Otherwise, I would have to move the cables by one connection and it would look like this:
And, before you ask, the distributor shaft is positioned according to the manual:
What's your experience ? How should it be properly done?
tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
#2 Re: Correct distributor position?
Post by mgcjag » Sat Mar 07, 2020 10:08 pm
Hi Tadek.....is your timing pointer set at 10deg btdc (static)on the crank pully...and your vernier scale on the vacume unit set to the mid point...Steve
#3 Re: Correct distributor position?
Post by abowie » Sat Mar 07, 2020 11:55 pm
This is correct.
ysmalkie
Poland
#4 Re: Correct distributor position?
Post by ysmalkie » Sun Mar 08, 2020 10:24 am
Yes Steve, of course..
Tadek
Jaguar XK120 OTS
ysmalkie
Poland
#5 Re: Correct distributor position?
Post by ysmalkie » Sun Mar 08, 2020 10:30 am
This is correct.
Trouble is, that in such a position the vacuum pipe touches the water pipe. I could move the water pipe inwards on the bracket a bit, but the two will be very, very close...
Tadek
Tadek
Jaguar XK120 OTS
#6 Re: Correct distributor position?
Post by mgcjag » Sun Mar 08, 2020 10:35 am
Hi Tadek....a 3.8 photo ftom the factory fit section
ysmalkie
Poland
#7 Re: Correct distributor position?
Post by ysmalkie » Sun Mar 08, 2020 6:01 pm
I know this photo very well. There are others that indicate same position, too.
However I am always sceptical to photos where something is wrong, such as the vacuum suction pipe must have been broken off and the tip was replaced with the rubber angle connector from a later car....
Well, I guess you are right, I just need t move the water pipe a bit..
Tadek
Tadek
Jaguar XK120 OTS
Mich7920
#8 Re: Correct distributor position?
Post by Mich7920 » Mon Mar 09, 2020 6:10 am
This link could interest you.
viewtopic.php?f=3&t=14155&p=115168#p115168
Mich
Michel
